Selfrunning waterhose water perpetual motion experiment by Tony Hughes
Started by hartiberlin, July 23, 2009, 05:37:08 PM
hartiberlin
Hi All,
I got a picture from a user, who had problems to post it himself.
Here is a perpetual gravity experiment, where water is always sucked up
a hose and due to its weight in a long hose is always running in a circle.
So water can the pumped perpetually up a hill.
Here it is:
I used a bucket of water that was continuosly filled by the faccet. I used a 12 foot piece of hose(it was what i had laying around). the hose was positioned 2 feet straight up out of the bucket. then the other ten foot flowing in a straight line away from the bucket. I tried twisting the hose back around to the bucket but the flow would stop. on a level surface i measured how deep the hose was in the bucket(WATER INLET), then at the other end i measured up until the flow stoped. what i came up with was about 2inches difference(ABOVE WATER INTAKE). now i will say that the flow of water was alot slower above the intake point but WAS continous.I hope this email gets to you and i hope you try this for yourself.  TONY
> > From: Stefan Hartmann
> > Subject: Re: my experiment
> > To: "tony hughes"
> > Date: Thursday, July 23, 2009, 12:02 PM
> > Hi,
> > did you already post it on overunity.com ?
> > If not,
> > are you going to open source it or do you want to patent it
> > What is the status of this invention.
> > As it seems the water weight of the 10 foot hose is the
> > secret to draw up the other water...
> > How big and what diameter was the hose ?
> > Was it a special hose with low fluid friction inside ?
> > Many thanks.
> > Regards, Stefan.
I didn`t post it cause my pic is to big for website You are welcome to post it if you like. I used an ordinary garden hose(hose did not have screw on ends it was just a old piece of garden hose i keep for siphoning gas) for the test. It was your post that intriged me to try it.  I do not think there is any thing to patent here   OPEN SOURCE ALWAYS.  If you have an old garden hose laying aropund try it and saee if you get the same results.   TONY
hartiberlin
It seems, the key is the right side 10 foot long hose.
If the weight of  the water in it is bigger than the
atmospheric pressure, then it is able to suck up the water 2 foot on the
left side and we have a perpetual "water mill"
Anybody with a long garden hose in his garden can please verify this ?
Many thanks.
Lilhawk
ok thought about this.....I don't think this works because gravity applied to the water is at very low angle ( 11 degrees ) . made a quick picture
using just weights and a ramp. the principle should still be the same  and threw in numbers ..  basically 1 ft of water = 1 lb
you can see its basically evens out
