Patents involving antenna and aerials, mainly for transmitting...
Started by the_big_m_in_ok, July 24, 2009, 09:37:48 PM
the_big_m_in_ok
In numerical order, for reference:
#6,463,875
#6,147,655
#5,914,692
#5,841,407
#5,835,066
#5,805,114
#5,734,353
#5,404,117
#5,159,332
#5,065,099
#4,922,261
#4,804,965
#4,701,764
#4,633,250
#4,628,299
#4,622,558
#4,473,163
#4,407,000
#4,396,920
#4,028,704
#3,931,577
#3,721,989
#3,716,861
#3,568,205
#3,534,372
#3,530,430
#3,495,264
#3,267,476
#2,957,103
#2,955,223
#2,856,605
#2,813,242
#2,584,314
#2,581,348
#2,537,191
#2,510,162
#2,503,010
#2,373,206
#2,153,975
#2,145,024
#2,143,437
#2,135,234
#2,066,690
#1,740,851
#1,602,085
#1,575,824
#1,538,466
#1,504,303
#1,350,100
#1,315,862
#1,101,533
#1,014,719
#795,762
#674,427
#287,973
--Lee
the_big_m_in_ok
Had to quit when computer began acting up---wouldn't respond to keystrokes and bold letters appeared without being invoked by me---last entry has all bold letters and I didn't do that...
3,646,562  Helical Coil Coupled to a live Tree to Provide a Radiating Antenna
Has a toroid wire circling a tree trunk with a crossover caduceus arrangement combined into the design:
http://www.google.com/patents/about?id=Na4vAAAAEBAJ&dq=patent:3646562&num=100
#3,434,678 Microwave to DC Converter
Receives microwave transmissions to a dipole antenna on a "helicopter" UAV using full wave diode bridges:
http://www.google.com/patents?id=j3hzAAAAEBAJ&pg=PA1&dq=contrawound+antenna&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#3,278,937  Antenna Near Field Coupling System
Potentially large system, designed for transmissions, that combines multi-conductor arrangements into one conductor with air core coil:
http://www.google.com/patents/about?id=7nhIAAAAEBAJ&dq=patent:3278937
#2,550,891  Bifilar Inductor
Two counter wound Cadeceus coils in series, each having offset nodes---unusual:
http://www.google.com/patents/about?id=tqFdAAAAEBAJ&dq=patent:2550891
#2,387,116 Radio Antenna System
Fig. 4 has an embodiment featuring a 3 dimensional arrangement that can be wired in series:
http://www.google.com/patents/about?id=9Tp-AAAAEBAJ&dq=patent:2387116
#2,171,256
This one has a central tower and more than one transmitting elements on the outside with air core coils at the bases(figs. 4 & 5).
http://www.google.com/patents?id=p6hcAAAAEBAJ&pg=PA1&dq=toroidal+array+antenna&num=100&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
--Lee
the_big_m_in_ok
#4,839,616
This is a "transformer" made of a transmission co-ax cable wired in either two or four sections.
http://www.google.com/patents/about?id=3NAsAAAAEBAJ&dq=patent:4839616
#4,115,778
Here we go!  2 wires facing each other like a Lakhovsky transmitting coil/antenna with attached electronics for specially invented purposes.  (You might disregard these electronics.)
http://www.google.com/patents?id=wsgsAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
#3,949,407
This is a 4-wire spiral transmitter aerial that's connected at the center by what amounts to approximately a full wave diode bridge
http://www.google.com/patents/about?id=4BYxAAAAEBAJ&dq=patent:3949407&as_drrb_ap=q&as_minm_ap=0&as_miny_ap=&as_maxm_ap=0&as_maxy_ap=&as_drrb_is=q&as_minm_is=0&as_miny_is=&as_maxm_is=0&as_maxy_is=
#3,617,980
Fig. 14A-E may be a description of how a Caduceus coil works
http://www.google.com/patents?id=1OgBAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
#3,614,732
To transmit info between 2 moving coils.  Fig. 3 has two counterwound flat spiral coils in series.
#2,919,442
You might try this with a Tesla coil
http://www.google.com/patents?id=WYFVAAAAEBAJ&pg=PA1&dq=counter+coil+antenna&num=50&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#2,682,608
Basic counterwound bifilar
http://www.google.com/patents?id=OzBtAAAAEBAJ&pg=PA1&dq=counter+coil+antenna&num=50&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
#2,650,303
Upper and lower square coils with a center-tapped air coil between them:
http://www.google.com/patents?id=yT9cAAAAEBAJ&pg=PP1&dq=counter+coil+antenna&num=50&source=gbs_selected_pages&cad=2#v=onepage&q=&f=false
@onthecuttingedge2005 + all others...
Do you realize some of these patents may be usable in spacecraft designs?  Especially the spiral toroidal wound Mobius ones.
--Lee
the_big_m_in_ok
FreeEnergyInfo
http://www.perendev-power.ru/NET-Journal_Russian_version_interview.pdf
http://peswiki.com/index.php/Directory:Wang_Shum_Ho_Generator
http://www.efir.com.ua/tmp/motk1.pdf
http://peswiki.com/index.php/Directory:Electromagnetic
http://www.wilhoit-az.com/mark/free_energy/MAllen7424.php
http://alexfrolov.narod.ru/rusbogomolov.html
http://www.free-energy-info.co.uk/PJKBook.html
http://www.emanator.demon.co.uk/bigclive/joule.htm
http://www.bigclive.com/joule.htm
http://www.energeticforum.com/renewable-energy/3609-big-joule-theif-11.html
http://peswiki.com/index.php/Directory:Magnet_Motors
http://freeenergynews.com/Directory/index.html
http://www.uawinfo.com/UAWINFO_HHO_GAS/uawinfo1.htm
http://www.uawinfo.com/UAWINFO_HHO_GAS/1568%20pdf/1586%20pdf%20Book.pdf
http://radosvet.net/politikos/finans/3154-bestoplivnyje-generatory-firmy-proizvoditeli.html
http://radosvet.net/news/952-magnitnyjj-dvigatel-baumana.html
http://www.fdp.nu/default_cached.html
http://www.fdp.nu/perendev/default.asp
http://www.akoil.de/index.php?lang=en
http://cycclone.com/
http://www.searlsolution.com/
http://www.energospace.ru/2008/02/12/jelektromagnitnyjj-dvigatel.html
Kapanadze
http://peswiki.com/index.php/Directory:Kapanadze_Free_Energy_Generator#Photos
http://www.overunity.com/index.php?topic=7679.0
http://www.overunity.com/index.php?topic=7679msg189076#msg189076
http://www.hvlabs.hu/zpe/Gruz/
http://www.matri-x.ru/forum/index.php
http://www.greenvaltd.com/ru/video.html
http://www.hvlabs.hu/zpe/Gruz/index.pdf
http://www.hvlabs.hu/zpe/Gruz/kak_rabotaet_Kapanadze.doc
http://ru.thefreedictionary.com/
http://www.tmzenerji.com/
http://www.youtube.com/watch?v=wV560xfYSJ0
http://www.youtube.com/watch?v=fc0J6ZNpybM
http://merlib.org/aggregator/sources
http://www.elektronika.lt/theory/theme/159/121/
http://lt.diplodocs.com/   / prekiu instrukcijos /
http://empyros.org/?j=id_&avt=vsk&sod=019
http://www.overunity.com/index.php?topic=7679.msg189060#msg189060
http://arena.net.ua/econom/2221.html
http://radosvet.net/file/video/3225-ezdim-na-vode.html
aramenko
http://jnaudin.free.fr/html/afep01.htm
http://jnaudin.free.fr/html/fep01.htm
http://jnaudin.free.fr/html/afep012.htm
http://my.mail.ru/community/iwalushen/journal
vitanar.pochta.ru/autors/korneev6.htm
http://www.astrolab.ru/cgi-bin/manager2.cgi?id=40&num=1378
www.sciteclibrary.ru/rus/catalog/pages/3095.htm
www.skif.biz/index.php?name=Pages&op=page&pid=13
www.skif.biz
http://www.vitanar.hotmail.ru/AVR/AVR.htm
http://www.trinitas.ru/rus/doc/0231/008a/02310053.htm
http://www.keelynet.com/energy/prentice.htm
http://www.free-energy-info.co.uk/Smith.pdf
http://www.free-energy-info.co.uk/Combine.pdf
http://www.arrl.org/tis/info/pdf/9708033.pdf
http://prs-rover.narod.ru/biblitek/motovilo/motov1.djvu
http://prs-rover.narod.ru/biblitek/bibliotk.html
http://prs-rover.narod.ru/biblitek/book6.html
http://dc87.4shared.com/download/118160052/ebbe49c6/_Ebook__The_Free_Energy_Secrets_Of_Cold_Electricity_-.pdf
julie tief
http://www.overunity.com/index.php?topic=6123.310
http://www.overunity.com/index.php?topic=6942
http://www.overunity.com/index.php?topic=6309.0
http://www.overunity.com/index.php?topic=6123.8860
http://www.overunity.com/index.php?topic=7842
http://www.overunity.com/index.php?topic=6942.160
http://www.overunity.com/index.php?topic=7679.710
http://www.overunity.com/index.php?topic=6123.9040
