Thane Heins BI-TOROID TRANSFORMER
Started by shimondoodkin, July 24, 2009, 11:33:44 PM
teslaalset
@Bruce,
The complexity is a bit higher than the simple explanation described in the patent.
A ferromagnetic core does not have a permeability of just one value.
The permeability of a core is very much depending on its magnetization state.
So, it may look simple, but there is more to it.
I agree though, it's an interesting concept worth to be investigated.
Bruce_TPU
If I understand the patent correctly, it is primarily the reluctance of the metal for the two coils of the secondary, being different than the reluctance of the metal of the primary.  The flux path in the metal for the secondaries becomes the path of least resistance.  This in turn allows for energy gain.  And not just a small amount of COP.  3200%!!
Many on this board have spent a great deal of time (years) and money, trying to achieve COP >1.
Thane, who was once a major contributor to this forum has discovered something far more important than his earlier experiments.
I wish for all here to read the Patent and to come to their own conclusion and to attempt replication, on any scale.
EDIT:
The link appears to now be again working!  (YEA!)  Link is two posts above!!
Cheers,
Bruce
IceStorm
I dont think the principle describe in this patent is valid, look at the timeframe, it was filled in 2007 and follow the development of Thain and the timeframe, something wierd no ?
Best Regards,
IceStorm
Bruce_TPU
Perhaps, or perhaps what was originally was submitted by Thane in 2007 was later "updated" by him.  Jan 2009 it was opened for public inspection.  I do not know enough about the Canadian Process to say for sure.
What also impressed me about this patent, is there appears to be an engineering company that tested and validated some claims, inside of the patent.
Cheers,
Bruce
Sprocket
I have a question - the patent states that flux always takes the path of least reluctance and cites that doubling the area of the secondary core material will result in it being half the reluctance of the primary.  Assuming the same core material throughout, will this simple doubling of the secondary's area result in ALL secondary BEMF flux being routed through it, or just a greater proportion of the overall flux?  If yes, then why bother with 'exotic' core materials!
This certainly seems one of the easiest OU areas to prove/disprove.  The 3000% efficiency of the prototype suggests that any old core material, appropriately sized, should show >1 COP...
