New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
Groundloop
@CompuTutor,
No problem, I always get my two big coffee jars before logging in to this forum. :-)
So, do you think my circuit can produce the needed wave output? I was thinking that the
control input could be a micro controller (connected to an A/D converter) generating the
needed wave input for the bridge.
Regards,
Groundloop.
CompuTutor
Yes the presented circuit should do fine.
And you didn't use a floating +/- supply,
just a single-ended one.
All a matter of (Ground) reference really anyway.
So the mean average of the output would be half the supply voltage.
Or to put it Ali's way: "not below zero volts"
I agree though, we need a diagram of what he is feeding to help him more.
I'm going back to bed, lol.
Groundloop
@CompuTutor,
If his circuit has just a two wire input then all you need is a single supply.
I agree that we need some drawings from Ali to be able to help him more.
(Have a good night sleep. :-)
Groundloop.
winsonali
the circuit designed by ground loop is a perfect power circuit for converting DC into AC and with micro controller you can achieve different frequencies and  duty cycles
the cmos IC's can be used for Ac conversion but they have limited power output
the circiut designed by ground loop is basically flip flop AC which changes the positive and zero between 2 wires this technique is used in SMPS inverters and they work very fine but there is no below zero  reference in there.
consider a magnet with N and S terminal and the forces are balanced in the center
this can be replicated in a center tip transformer this is why they can produce below zero reference
try to understand the harmonics of AC cycles are more then the harmonies produced through DC converted to AC this is because the DC works in only one quadrant and electromagnetic Ac works in 2 quadrants
Ac is just like a wheel with a rotating center axis and DC is just like a square block of wood
Batteries can only produce DC coz there is no way to transfer charges in ionic medium with nill polarity that is some thing between anode and cathode
negative supplies are rarely used now a days there were normally used in valve circuit
The negative supply are good for high power RF PA
the easiest way for my circiut is use of opamp with dual supply as comparator this gives me out put on single wire but here the problem is we need an op amp with dual supply that can handle 5~10 amps
this is not a normal requirement so manufacturers do not produce such devices off the shelf
well on the other hand a triac can handle heavy currents
i have developed a new circuit and right now i am designing its PCB
well while i was using transformer for the input section i though its a good idea to test some new method i review the use of PM in transformer and my finding were just like other members of this forum there is some thing missing in that technique
recently based on my own theory i manage to develop electric current without inter crossing the magnetic field the result is 1 volt with some good current
these experiments lead me to many question in order to improve the process the question i posted in my last posts
i will repost those questions in next post
please do not consider that i am diverting direction of discussion we all know the problem of intelligent people that ideas always clouded our minds and quest of perfection is the enemy of work completion.
winsonali
questions in my posts
QuoteI was basically designing input section of genie without a dimmer with AVR capability then i think about using permanent magnet in a transformer that experiments failed and i saw number of patents dating 1954, to 1978 and i also review Tom Beardom's MEG i realize something is not right in this method and i developed this new technique of using magnetic field with out inter crossing and produce good  use able electric power. These are really new lines of working with magnetic fields this involves highly precise sensing circuits and software
Few results of my experiments raised these questions
1) what is the speed of magnetic lines
1A) what is the frequency of magnetic lines.
1B)  what is the resonant frequency of any magnetic material.
1B) an aluminum wire coated with silver offer good conductivity(current travel on surface area), but eddy current is highly reduced
2) why a stationary magnet do not produce eddy current or electro magnetic current in a coil which law define this part?
3)  an air core coil when in operation produce and offer electronic characteristic showing blocking AC current, exhibiting current lagging , LC circuit acts like pendulum , but it don't attract metal as a magnet until and unless it has some permeable material experiencing its current flow
in my experiments i am developing methods for  reducing the eddy current loses, inter crossing of magnetic forces even then you can generate good amount of electric current
these are really new lines of working with magnetic field This involves highly precise sensing circuits and software
its time for brain storming
