New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
wattsup:
aaron:
i have explained a little bit how you can get the max power and efficiency
please see the attached picture
aaron5120
Quote from: winsonali on December 26, 2009, 04:17:29 PM
wattsup:
aaron:
Hi Winsonali,
Seanson's greeting to you and your esteemed family!
Many thanks for your efforts in clarifying the wave switching issue in the magnet=coil setup. In light of your most recent explanation, let me see if I understood the information. The coil enters the center zone(the iron cylinder center) of the Disk magnet pair and the controller circuit switches the coil "on" to extract the peak power, then switch "off" for leaving the center zone. You use the outer zone( the own magnet surface which has an opposite polarity comparing to the center zone)) to demagnatized the coil in order it can leave the magnet pair without drag.
Therefore, the special magnet shield setup can save the energy required to demagnetize the leaving coil  in order to overcome the attraction force.
Am I right? The solution is brilliant and simple.
So how could the controller circuit know when to switch on and when to switch off? Using hall effect probe, or using one of the numerous opto-coupler to trigger the switching?
Thanks for sharing your technology, Winsonali.
aaron5120
winsonali
aaron:
we don't need any hall effect sensors in our circuit
we are sampling wave shape in software we have an ADC and a DAC in software developed to monitor  wave shape as we cross a certain voltage on middle coil we turn on load Mosfet and as it goes down a certain level we close the load  so you are not very much concerned about magnetic field
using hall effect sensors is not good practice for open loop magnetic circuits you will not find them in various high end solutions coz they can receive effects from environment RF emissions and a lot more but induce voltage is the target and as well as 100% end product sensing PD and controlling is the best solution
nightlife
It looks to me like this is nothing more then a very well built Joule thief. Kind of like a bedni circuit that pulses the power and collects the power from the colasping field. What would be really nice to see is a circuit that could be used to collect the colasping field of natural energy without being manually pulsed. All energy pulses as do all vibrancy's and considering everything is made up of vibrant, everything pulses. Nothing is solid and everything is vibrant as well as everything is energy. Energy is vibrant and vibrancy's are energy.
aaron5120
Quote from: winsonali on December 27, 2009, 07:02:21 AM
aaron:
Hi Winsonali,
Now I understand what your programable IC does in the controller circuit after your explanation. Thank you for the information.
I already got 10 pieces of grade 5 ceramic disk magnets (see attached picture of it). Their dimensions are: OD 81.5mm, ID 40mm, thickness 15mm.
I will get the iron shield (see another attachment)made with the base diam. 80mm, thickness 4mm, and centre rod diam. 36mm( to be 2mm smaller at each side of the ID of the magnet), and 17mm long( 2mm longer than the thickness of the magnet.
Please confirm the dimensions of the shield if they are all right. Many thanks!
