Bedini pulse charger buster
Started by Silvije, September 04, 2009, 11:43:33 AM
Which buster schematic just might work (produce "free energy") in your opinion?
1 - 2 bifilar coils
2 - 1 trifilar coil
3 - 2 bifilar coils
4 - none of them
Silvije
This is in fact "double" Bedini pulse charger which uses 2 batteries which charge each other simultaneously. I called it "buster" because if the Bedini circuit does not do anything unconvential, the batteries will eventualy be both depleted... however if the charging captures some of the "energy of universe" this circuit have a good chance to be perpetuum mobile :) which I doubt.
There is no need to swap batteries or anything, first battery is charging second and vice versa...
you are welcome to comment and to build this circuit of course and tell us all what's up
Silvije
oh yes, please dont mind the exact parts instead try to understand the circuit...
Silvije
this should be same thing only with just one battery which charges itself and you would need trifilar coil...
funny, so many views but no comments, maybe if I named this topic "self runner" I would be having at least a dozen of replications already ..
dont mind coil winding orientation, I just could not find better element in eagle... idea is that both trigger coils are energized at the same time and they "open" both transistors, current flows through main charging coil and energizes it, than after some time both transistors are "turned off" at the same time and induced current from the charging coil goes back to battery...
Silvije
Groundloop
Silvije,
Nice work and a very good idea.
Attached is my try at your circuit. I have also attached the Eagle CAD files if anybody want
to make a PCB later on. What are your plans for rotor on this setup? A bicycle size type or
something smaller? Is the intended use of magnets all facing North out or do you plan for
an alternating North South system?
Regards,
Groundloop.
