COAX TPU...
Started by innovation_station, September 05, 2009, 10:05:51 PM
BEP
Quote from: Gobaga on November 30, 2009, 08:49:20 PM
Steven's toroid looks like a toroidal isolation transformer wound for high voltage.  Single winding to keep the high potential end from the low potential end and looks like a high voltage isolator in the middle.  That flushes the saturable reactor idea down the crapper.  Ol' Steve would have used this to isolate the pulse coils from the signal source.  Can't have  freaky stuff screwing up the timing.  See attached:
Thanks for the pic @Gobaga.
Unfortunately, your pic may look similar to the one on the TPU to most but not to me.
@szaxx
Pincushion correction cores! Last time I heard that term was probably in the late seventies.
A possibility..... I need to look into that.
Thanks.
BEP
Ah yes!
http://www.freepatentsonline.com/3566181.pdf
Split and reversed poloidal windings around a solenoid winding. This explains why the typical rounded edges of the core are not shown. It also explains why the outer diameter thickness is more than the inner diameter thickness.
This meets the description I see and others don't and still allows it to work as a saturable reactor.
Gobaga
Quote from: BEP on November 30, 2009, 10:46:13 PM
Ah yes!
sat reactor came later - his core looks a little funny and is probably insulated
Anyone pulsing should recognize that toroid by now.  Grumpy had one on his avalanche board.
BEP
@Gobaga
No disrespect intended but...
The patent link I posted is the first truly similar toroid to the one used in the TPU I've seen discussed or posted by anyone on this board. The little toroid on the TPU is not a common garden variety toroidal inductor/transformer nor does it look like one.
Folks should really look closer. To me it is obvious.
1. They are different
2. People seem to want everyone else to think they are the same.
You can build one the way you wish using a common toroidal core, with any winding configuration you want. It will never look the same as those shown on the videos.
szaxx
hi all,
Not got too much info but can recall the effect of what I think you are saying about the split reversed windings on a torroid. At Uhf  you would find this effective for radiating emf, look up collinear antenna it may be nothing to do with it but as a frequency dependant circuit it may be part of the feedback control to prevent runaway, just a thought.
do we know that it isnt just a current transformer
Steve`
