Yu oscillating Generator ---- Overunity YOG Model
Started by WattBuilder, September 14, 2009, 03:19:15 AM
spoondini
Howard,
    Nice to see some updates.  Sounds like you're making progress.  Have you had any success with 2 cycles yet using the windvane mechanism previously mentioned?  I'm following your developments with interest.  Continued acceleration through multiple cycles will be the proof your concept will work.  The novelty of mixing a magnetic motor (kind of) with a pendulum is something I've never seen before.  It just might work.
So you're saying that you have confirmed continuous acceleration in 'slow motion'!!!!!  That's awesome.
spoondini
Was just thinking (dangerous)...
Before we pop the cork on the champagne bottle and celebrate the first perpetual motion device in the history of mankind, I realized that you are adding energy every time you stop the device and manually turn around the magnets.  Kind of like a SMOT, you have to position the ball each time (adding energy). Although this might seem negligible, you're not gaining that much energy with each oscillation, and the act of turning over the magnet, whether using electric, air resistance, or gravity will create a drag on the unit potentially wiping out the gains.  In short, the experiment you conducted is not conclusive and what you deemed as trivial is now the determining factor as to whether the YOG will achieve OU.
The final proof will be in a self running unit that does not rely on external power or tampering of any kind.  Not yet ready to start throwing any $$'s at the device until we hit the undisputable point of OU.
Quote from: spoondini on October 19, 2009, 09:20:13 AM
First in history, lol have you been sleeping outside?
Anyway that's the whole point isn't it, to spin the magnet on the rod. The magnet is so far out of the field that you can call any effect on it negligible. So the only thing that remains is to use some of the energy you gained to spin the setup. But even in theory the magnet on the rod is pretty symmetrical so it should technically take no energy at all to spin it. I encourage that the first setup should be completely mechanic to blow any talk of energy input out of the water.
spoondini
Broli - I'm also very optimistic about this setup, but by nature I'm a critical thinker and extraordinary claims require extraordinary evidence.
BTW - You implied that there are other perpetual motion devices, could you please point me to one that has been undisputably demonstrated (not one where the inventor disappears and we are trying, but unsuccessfully, to replicate).  I know of pendulums which have swung for years, but they will eventually stop.  The Finsrud will run for a couple of months before being reset.  I would love to see a genuine perpetual motion device.
Quote from: WattBuilder on October 19, 2009, 08:44:50 AM
Hi All,
This new array set up seems to out perform my previous array by about 6 inches. Its based on repulsive force is greater then attraction force.
I’m going to be switching over to this for future testing until better comes along.
Howard
My one cycle video http://www.youtube.com/watch?v=gekDM8vg16k
Have you considered using a halbach array and compare that to your current results. It should make the field about two times stronger.
http://www.skytran.net/phpsite/media/inductrack%20halbach%20array.jpg
