Share your coil designs
Started by onthecuttingedge2005, October 06, 2009, 02:40:56 PM
Doug1
Can someone fix the formatting on this thread? One of you pasted your post from note pad and fouled up the works. Note pad ,the ultimate waste of space. Try word pad instead and set your margins to less then 3 feet.
void109
Quote from: Doug1 on November 28, 2010, 10:03:55 AM
Notepad pastes plain text, word and word pad both create HTML IF the wysiwyg editor supports formatted pasting.
Back on topic - does anyone knwo what HHOforVolts is doing with his new super starship coil winding?
See: http://www.youtube.com/watch?v=xKXtNhNPRU8&feature=sub
the_big_m_in_ok
Quote from: stevensrd1 on November 28, 2010, 03:06:10 AM
@big_m
What I meant was the actual wire that is used to make the coil, what if that wire was made out of a metal, that a magnet would stick to. For example like coils used in magnetic energy generators, that have a metal core in them, with wire wrapped around them. But if the wire itself was made of a metal, that a magnet would stick to, then no need for a metal core, as the coil itself would act as the metal core.
Well, if the coil was in the shape of a rod, it would have a North and South Pole, right?  Especially if the input leads were on opposite ends?
Would this enhance electrical generation, guess one would have to try it to see.
If it was in the shape of a toroid, maybe?  The patent(s) indicate that signal transmission is maintained in integrity, so that might amount to something?  At least induction is directly proportional?  You might be right:  Experiment.
--Lee
the_big_m_in_ok
Quote from: void109 on November 29, 2010, 10:08:51 AM
I saw what he was trying to do without sound(no headphones at the time): A series of scope shots of possibly stepping up the BEMF frequency?
But all he showed was a breadboard of what might have been a solid state Bedini setup.
Other than that, without both the video or a circuit to look at as well, I don't know.
--Lee
