Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
forest
I was thinking .... You know why TPU may be so hard to replicate ? Because it is only a transformer , the input force is made in other place, TPU is only converting it into stronger "current" to feedback to input.
GK, good point about torroids !
It is probably very simple : a source of special etheric force,the transformer to enlarge it ,feedback loop to source , kind of current and heat limiter and the output of course.Actually TPU shape may depend only on Tesla torroid transformer idea.
agentgates
Another thing I noticed. In SM's demonstration (I don't know what id you use for that TPU here) when he inverses the device and turnes it back at 2:10 a few frames after clearly shows that 3 thick copper wire come to the topside disk in 90 degrees offset to each other. Therefore I presume that there is another on the opposite side covered by the medium section plastic tube.
sumermagor
i see what you mean on Diamagnetism, we need tests,
The strongest Diamagnetic stable element in the periodic table is Bismuth,
It also emits some alpha particle radiation,
I have half a kilogramm of that, might try something with it,
And Yeh The thing is, it is 1000% very simple, but its very tricky ;)
There are always things that are the most easiest but in some case the most hardest to replicate,
But i have actually found a way now, im going to draw diagrams again,
My idea is Sm using Multiple Induction coils... not 1 not 2 but more possibly many many layers, Like NIKOLA TESLA did back in 1888, You can see how many layers of copper wire he used as the outer cores,
to understand this please check this video
http://www.youtube.com/watch?v=jMq657dgYT4&feature=player_embedded
I think this is the technology he used, capturing the torsion field with multiple resonant coils,
VERY SIMPLE
i think this is the way to go, since that LED lights up from Nowhere, i think Sm used many coils to wind up in a core in the middle, and connected them with diodes to make The flow of electrons in one direction.
then the two resonant coils upper and down side were focusing that torsion field in one direction and that is in the MIDDLE COILS.
and the toroids could be there to make usable electricity, there could be a high frequency pattern ((using small electric components)) set up in there
Im going to do a clear Experimentation with photos, so if the idea works, we got it.
We have to be open To everything Since we dont see behind the things,
I allways say LETS SEE WHAT HAPPENS NEXT!:)
Best wishes
Sumermagor
agentgates
Quote from: sumermagor on January 01, 2010, 08:17:45 AM
That is true - one of my favourite elements - but if you have a crystal cluster it won't work and don't ruin that. You need a THICK bar or tube. The same or similar effect you'll get than at the Meisner-effect with a superconductor. Search on youtube with "bismuth levitating" or so.
I have seen this before, but this is actually an antenna tuned to 50 or 60Hz with low output current. SM's devices give high current.
I popped in with diamagnetism as I have seen a HUGE copper bar bent into a "C" shaped curve on one of Don Smith's devices and remember what SM said about the THICK copper collector coil. I've got copper bars on the loft I'll bring them down and play around with that.
[off]Bismuth is also the best Hall-effect semiconductor that changes it's resistance in magnetic field. That is what I use it for.[/off]
