Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
sparks
   This experiment with the stout copper bars etc was done and documented by Tesla.  I would like to apologise to the poster who went through the troube of uploading a complete text of a book The Inventions Researches and Writings of Nikola Tesla by Thomas Comerford Martin for I am indebted to this person for his efforts and can not find the link on ou to get his name and thank him properly.
  I do believe that SM used the rotation of a standing wave while Tesla used the oscillation of a standing wave.  (a standing wave only stands relative to time and can move in 3d)  Well anyway if you can move the nodes and antinodes of a conductor that is in standing wave mode they will alternately change the polarity of a capacitor plate by electrostatic charge and discharge of the plate that is geometrically in alignment with the nodes.  The electrons in the load circuit respond to the electrostatic field and migrate through the load until they terminate on the plate.  Towards the antinode and away from the node.  The capacity determining the amount of current flow through the load.  If the node and antinode are caused to migrate the current is then reversed in the load circuit until the plates are equal in charge.  If the nodes return we get pulsed dc to work with if they are circulated then we get ac.  This is due to electrostatic induction. Cold currents converted to hot currents by the electrostatic charging of a capacitor.
   Tesla used the electrostatic "movement" of polarized mass to instigate longitudinal waves through a compressible medium.  The electrons dont move persay they get more dense or rarified just like air molecules transmitting sound waves.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
EMdevices
8 ) If the LED does not light up what does this mean. We need to know why a connected CC is acting like a cloaking medium.
It does NOT light up,  and this is easily understood by induction theory.  This extra "CC" winding is also a one turn loop, that is shorted, so it shorts the external field and it can't induce energy into my resonant loop.
EM
wattsup
Quote from: EMdevices on January 01, 2010, 05:49:37 PM
EM
@EM, thanks this says alot.
forest
Quote from: sparks on January 01, 2010, 04:45:32 PM
Good catch sparks.This is why Fig 2 is in Tesla method of conversion patent.
wattsup
Quote from: wattsup on January 02, 2010, 02:56:05 AM
@EM
It was late last night so let me just expand on your response of #8.
Would it not be reasonable to assume that since you know that a shorted CC on a ring prevents transfer from the ring to the coil, and an open CC does not, that given the design of the FTPU, ring with CC, that if SM was using the ring to coil HV transfer method, that either the FTPU CC was never connected or...............
This is the "or" part, in order for him to use the ring, he basically used the CC via a small transistor that would open and close the CC short. A very small transistor because all you are doing is opening and closing a non energized wire and by doing so you are pulsing the ring without any direct intrusion, a virtual on and off of the ring that would then pulse a signal going to the coil. Why pulse. because we already know from so many other tests that pulsing create peaks.
If you have gotten to stage #8, the other stages would still be valid to try from that perspective to better understand what is going on. Then even try the same test progression with an aluminum CC.
Anyways, since I do not have a working ring/coil, I cannot myself answer or try to further this, so I will leave it alone. I definitely do not want to come across as a pestering idiot, so let's just move on then.
