Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
e2matrix
Glad to see you back GK.   Here is something possibly relevant to the TPU I just found in an ebook by an unknown author.
"Any transformer can be converted to OU device if taken to resonant or semi-resonant Easer (Electrical Amplification by Secondary Emission of Radiation) states.  Secret is right pulse intensity and length to excite the coil or and core to high energy electron active states and proper capacitor value for this energy to slide in logarithmic curve into a capacitor as a voltage potential.  Extraction is quite simply done in its blanking period, non-reflective to source as Easer mode is attained.  Temperature goes DOWN as pulse excites the CORE to sautration states, the collapse of the field transfers thermal component (and part of the time-space tensor) to energy potential into capacitors.  Now you have the secret to ZPE.  In a sense it is a "magnet-atomic resonance".  Quite interesting to note OU is there all the time and the mechanics to extract them are not really that complicated."
forest
I'm stunned.Not everything is clear to me, however : is it converting time to energy ? Not good then because everyone standing nearby will soon become old man. ;D
I agree that a correct pulse can do secondary emission (radiant energy) .
giantkiller
Thanks.
Another curious parameter is the 2 coils are placed at 90 degrees to each other. This has appeared in multiple places. The Cosmic Lattice document stated this as a gift to the ant hill but that it has not been utilized correctly.
http://www.overunity.com/index.php?topic=5793.msg130992#msg130992
QuoteHere's how it works. Two magnetic fields together, postured in the correct way -- a way that is very three-dimensional in your thinking process -- will create a "designed magnetic field" that is very specific. It's one you have never seen, and does not exist naturally. Start with trying many magnetics fields, postured against one another -- of unequal force and pattern, and at right angles. Don't make any assumptions. Think freely. Done in the right fashion, these two fields will create a third pattern, which is unique and is the product of the original two. This third custom created pattern is the one you what to deal with, and is the one that has the potential of manipulating the lattice. Once you have created it, you will know of its special qualities by how dramatically it changes the physics around it. It won't be subtle in its exposition -- believe me. You will know when you have it.
Time is heavily portrayed also.
Quote from: e2matrix on May 21, 2010, 03:15:07 PM
wattsup
Two JFETs blown.
Just getting the knack of them.
I just bought some of these off this Ebay seller - dirt cheap:
PN4416A N-Channel JFET High Freq Amplifier LOT of 100
PN4117A N-Chan JFET General Purpose Amplifier QTY 100
PN4118A N-Ch JFET General Purpose Amplifier LOT of 100
TIP32C PNP Power Transistor 100V 3A LOT of 25
DIODE MUR810 RECTIFIER 100V 8A TO220 LOT of 10
One of the links is here;
http://cgi.ebay.ca/PN4416A-N-Channel-JFET-High-Freq-Amplifier-LOT-of-100_W0QQitemZ370203831627QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5631de2d4b
Pdfs are included below.
Is it possible to use 5 to 10 of these JFETs in parallel to increase the handling capability because I would like to still use the IRF840 and the IRF9540 on the poles and use some of these in parallel in the center?
@Rosphere
One thing I (and others) have been bitching about for a long time is the diode in the mosfet. These JFETS do not have the diode. So depending on the design the flyback should now move freely back to source.
Is it possible that forgetting about JFETs is exactly what some would want. We don't use tubes anymore and soon JFETS could be a thing of the past. Why??????
Yes Yes, Mosfets are much better. Yeh, they fizz or pop more loudly when they blow. lol
Caps discharge on connection. Inductors discharge on disconnection. When used together, at the on pulse the cap discharges into the inductor, then at the off pulse the inductor discharges into the cap and that interplay produces a resonance. But when the Mosfet has that internal diode, part of that resonance is surely killed because there is no return possible to source which is an integral part of the play. I guess that's why they like Mosfets because once the energy passes it, there is no going back. Total consumption or waste is the only option.
Also, if some guys doing JT are using a diode in there, then you need to test your circuits with different diodes because each one will give you a result, some way better then others. Way way better. Incredibly better. You could be testing your device but not knowingly seeing results that are mediocre just because of the diode choice.
Anyways, back to the bench.
wattsup
Just thought about this also.
With these JFETs having no internal diode, I can test small scale Tesla Ozone Patent methods. The JFET should be able to be used to create a small short circuit to replace the rotary switch. Hmmmmmmm. Another avenue for more fun.
