Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
giantkiller
Previously posted using bifilar steel and copper. Kept coils at 90 degrees. Kept coils at a distance. Kept volts at 12v. Raise the mass and the voltage for higher effects.
Also:
http://www.tfcbooks.com/tesla/1919-07-00.htm
http://www.panaceauniversity.org/Magnetic%20Resonant%20Amplifier.pdf
http://merlib.org/node/5056
http://www.fact-index.com/t/te/tesla_coil.html
http://www.kuenstler-energie.de/COG/RESONANC.htm
http://www.patentstorm.us/patents/5004166.html
http://www.tumblr.com/tagged/Destructive+Resonance
And the big one:
http://www.byronnewenergy.com/wiki/index.php?title=Tesla_and_resonance
Thought you'd see something new? Been done before. Engineers avoid it.
Yep... banging fets and coils doesn't work. One must use finesse to coax the powers of nature.
I go back to building and configuring now.
sigma16
Quote from: giantkiller on August 24, 2010, 11:29:04 PM
Banging coils most certainly does work.  You just have to use a hell of a lot more than 12v nad a hell of a lot more than 10 feet of wire.
giantkiller
A top level decision needs to be made about this thread then:
Are we going to bang coils or finesse Mother Nature into a date with destiny?
The first way takes high voltage and the 2nd way takes a little more knowledge.
I can throw sledgehammers or a bouquet.
If you work outside then throw sledgehammers. If you work inside then carry a bouquet, its safer.
Mannix
Quote from: giantkiller on August 24, 2010, 11:55:01 AM
Lets stop this with a simple explanation:
EMd: back me up.
@All,
You take 2 transformers next to each other that are tanked. Resonate them 180d out of phase. You now have the model of Harmonic amplified resonant power or power amplification through harmonic resonance. This process blows shit up! Fuse boxes, pole pigs, towers, sound amplifiers. Now put this process to work between a generator and a motor. Can you say Johnson motor?
If you have never heard the waving buzz that sings across the chassis then you have no right to talk about OU! Kapeesh?
Don Smith used this also.
I don't know a better way to put this.
The tpus are 2 lc tanks resonating back and forth. Get this just right and you can collect. It is the echoing process that one hears and sees with guitar feedback in an amp. You can break equipment. Hello?
Ok, 3 guitarists each with tube amps  just close enough to speaker stacks  to keep their  notes sustaining.
Now put the voice coils in proximity to each other and a place of collection that just happens to have high voltage , low current applied with respect to a new "fake" ground reference.
Two of these, clockwise and anti clockwise , phase and anti phase .
Does  the high voltage current remain at milliamps?
Sounds like gobbledygook uh?
forest
Forgive me Master ,
I'm not sure I understood.Two tube amps to create distortion with amplitude rising and third to modulate it and swirl in phase to become output current ? Looks like two magamps in parametric oscillator and a control valve to me...
