Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
h2ocommuter
I have done everything to try to download these docs to a holding site scribd without success.  I did get one put on there under "h2ocommuter downloads" but the other one downloads and when I try to verify it myself it says they will not accept password protected files? what ever that means? this is for editing protection duuu! anyway I got these free but I didnot place a link to where I got it. Good idea though!
This one is the Meyer data report and the one primary part Stan is relating is how the signal being sent to the VIC is timed, and more particular the type or wire to use that facilitates the non amperage movement under magnifications of high voltage.etc, etc.
it is found in the, bookmark tool under- tech briefs sec 07
if you don't have this, I will email it to anyone.
dzndlideas@aol.com
On the other hand if someone knows where I can download this in a friendly environment, that's cool too.
giantkiller
giantkiller
Forgot to post the pic...
2nd pic And better yet... The green is copper speaker wire. This single turn slides around the spool and carries the secondary with it.
This piece is easily replaceable with an iron core wire if necessary.
If the secondaries have to wind in the opposite direction from the primaries then I just pull out the core and flip it over.
Quote from: giantkiller on March 05, 2010, 10:43:23 AM
@Forest,
So you are saying no 2 bucking coil configuration?
And my assessment is the core is copper?
The attached pic shows a straight run but That will be in a circle to the match Smith's and Mark's rings.
Is this what you are thinking?
That would match my Sport model previously posted. And the center toroid is an exact match at a smaller model and lower drive specs?
As I have shown I have a smaller center toroid. The small ones are easy to build or reconfigure if the specs change.
So by what you are saying my Sport model is a correct configuration and now make a smaller version to drive and feed back the bigger one.
I'll be back in 12 hours.
sparks
5khz hiss from fast electrons in the plasmasphere is popping up "hear" and there
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6V6T-46YCW19-7&_user=10&_coverDate=01%2F31%2F1981&_rdoc=1&_fmt=high&_orig=search&_sort=d&_docanchor=&view=c&_searchStrId=1236086608&_rerunOrigin=google&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=a251dc0ea2a5af4790a4b5a68b95de18
So if you develop a loop receiver and excite it to open up the aperature  (place hearing horn to ear) the probability of converting elf incidence upon an expanded field of interest may be enhanced.  It is theorized that the brain reshapes the cavity influenced by the vibrations of the tympanic membrane to become resonant at the suspected frequency of transmission.  In other words an older person often goes deaf because they hear too much.  The muscles used to tune the ear to specific freqs loose their ability to sweep tune the cavity. The brain is constantly tuning the cavity for those freqs that are of interest such as those a child would make if it were crying or the rustle of leaves a prey would make as it moved through the forest.  A spectrum sweep.  Once the older person is aware that you are speaking to them they hear you fine because by habit their brain tunes the ear cavity for amplification of the human voice signal pattern.  You get the huh or what then they hear you.  Just amplifying the whole deal doesnt work well because the scanner isnt working inside the ear cavity.  There are more intense vibrations but they are not coherent with the cavity.  Newer hearing aids are programmed to output a small instigation vibration and delay the signal.  The person is hearing you not in real time anymore but at least they are hearing you.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
forest
Giantkiller
Yes,something like that except I didn't thought about bifilar , just a coil wound on torroid from ONE wire
Take one wire and wind unidirectional coil.
I'm not sure I'm right just that idea blinked in my mind lately.Control and collector coils from the same wire. Flow in circle,feedback,maybe gain. Amplification of power in loop ? .Yes it looks like particle accelerator the only problem is how to wind acceleration coils (control coils ? I have always had problems which one is control and which collector but here it's quite obvious).Gain is visible too.
Now there are two possible scenarios : control coils produce field
in the direction of DC current or against it . I don't know which is correct.Depending on this choice control coils should be done in the same direction as collector winding or  opposite direction.But I see clearly that it has to be one wire coil matrix.And YES, Tesla patent is similar but he used iron wires as a segmented core of coil and mentioned generation of some fake currents because probably he connected one or more coils with iron core which created acceleration of current.
Remember it's only just my idea, maybe others thought about it previously, I didn't found that but what Mannix once posted was very very close to it.Unfortunately he posted unidirectional coil composed of 3 control coils of 3 colors and AFAIK feedback loops causing acceleration was not visible.
Gain is from slight acceleration of electrons in wire, means a slight higher current.DC requirement is obvious and it has to be probably  pulsed DC not plain flat DC to generate a lot of voltage kicks from BEMF which are then accelerated and converted into current kicks! The principle is the same as for Tesla coil flat pancake : coil are really perpendicular to each other and in no inductive relation yet some field causes acceleration of current .Gain is because accelerated current in next loop around causes a slight bigger "push" which creates as slight bigger acceleration. Snow ball effect.
All above is maybe just a garbage... or maybe not.
;D
