Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
Well that didn't happen in the house now did it?
If you have a simple coil and spark gap then that is the driver. All one to do is add bigger coils with fatter wire and Poof! With adding smaller coils and regular wire (to keep it safe in suburbia) one gets nowhere but keep crashing pcs, household relays, and test equipment. Whoopty, frickin doo! I need an isolated lab. My relatives imply this also. Even my dogs run away. Making the bigger stuff is not rocket science. Just pump up the potential to electrostatic levels and yer done. Page 30-31 Pentagon aliens. But in suburbia the neighborhood shuts down or the incoming cable/idiot tv area gets whacked. It is just too simple to make shit happen at this stage. It is simply off the bench now.
The little tests with small coils and no usable output is not nirvana, never was. That is why I knew the stun gun with a bigger mass stage at the end was it. No playing with the small stuff. I know this sport model is gonna fry stuff.
But I do need to add this for the benefit of every one. I bought D-link wireless. It has a really cool dongle stand at the end of a USB cable. Being Wireless stuff I thought is would be a good extender cable. NOT! It's like a metal helmet in the lightning storm. I ran the wireless dongle on one and my controller on another one and previously fried more equipment. Just got back to stage normal. So I have gone to wireless usb.
I want to make bigger stuff.
2.5 years ago Ironhead almost blew his arms off cracking water. Jason blew a field into his chest. I have the ECD built to spec. I fried thumb nerves permanently. Hmmm. How could there be a next safe step? I have a ozone coil on a pen barrel in referring to the Kunel patent. It doesn't take big equipment! Either the correct frequencies or spark gaps. The results have to be up in the electrostatic range. This is what it all points to. But all the bench equipment and suburban necessities work in the range below this and looks like a current sink or radiant sinking antenna.
I have only read 30 pages of pentagon aliens and have the explanations of this process in my hands. He spells it out in 5 pages clear as can be. I have to go to bed and regroup my other personalities into one cohesive think tank. I have no one in my sphere of relationships that even has a clue as to what I talking about in all this here. But danger is easily understood.
Quote from: sparks on March 31, 2010, 11:35:27 PM
   2.5 years ago I did this.  Grumpy and BEP told me not to do it again if I didn't want to end up typing using a pencil in my mouth.
   I did alot of work with ozone cells in water repurification and seen my share of coronal discharge but it was to an obvious ground.  This is the only time I have seen an open air discharge to nowhere.  I have seen plasma created like you are after when a pole pig shorted from primary to secondary and sent 20k into a building bridging the fused disconnect with about a 5inch gap.  Again there was an obvious potential setup between the grid and ground.  The current was resisted just enough to allow the primary pole breaker to stay engaged.  Then there was the time some water with salt in it sprayed a 460volt motor relay box.  I heard the hiss but was trying to minimize damage control like stop the water from spraying all over the control room.  Well the plant called for the motor to engage and so it did.  It blew the NEMA 1 enclosure cover right off the box across the room and by my head at a good 100 miles an hour.  Only thing I can figure out is that the hiss was producing hydrogen gas of some sort and the plasma from the contacts making ignited it.  The motor starter itself was fine.  The box not so good.  A little bloated.  Well on the day in question with the flyback pulsing the iron coil I was curious enough to insulate myself from ground and stick my paw a good 12 inches from the weird dually plasma things.  Cold ass ion wind heading from the ground to the coil.  You could cup your hand and feel the cold stuff fill up your palm then leak out around the edges.  That and not all of it was coming from the air I could feel it coming from out of my hand.  It is not the feeling you get when you radiate your body heat and cold is radiating in.  It was cold radiating out.  Weird as it gets.  Pretty dumb too but I lacked any kind of thermal sensing device and just had a gut feeling this was not your ordinary radiant em event.  I think this is what was happening but not so sure.  The coil was acting as a solenoid and providing a relatively permanent magnetic field of a torroidal nature.  The lead from the flyback was attached in the middle of the 6 turn iron coil so the current was creating like two solenoids  back to back.  The pulsed  electric field was causing ionization of the air on the ends of the iron coil and the current maintaining the split polarity solenoidal magnetic field lines.  The free electrons liberated from the air ionization started a current that followed the magnetic field lines from the iron coil.  Since the coil ends extended through a uhmw block and ions like to float they were accruing inside the electron current flowing along the magfield lines.  This kept on going until with the ions relatively cold but still very positive but lighter than air amassed inside the electron loop.  This positive pole was insulated like a low pressure area in a twister.  For any high pressure to get to it it would have to negotiate the hot electron circulation.  The cold feeling was the thermal energy drop of the mass of the air and my hand as electrons left the atoms heading for the little cyclone deal I had going.  Ions lack the thermal energy of the relatively hot electrons.  I am quite certain that if I had kept running this thing it was going to get cold enough to form condensation of water vapor and some eery fog as reported around other plasma devices running in open air.  I didnt need to wait around for that kinda shit to happen and pulled the plug.
166.204.44.125
Bruce_TPU
Hi GK,
I suppose you have seen the new Don Smith video's on youtube?
Well he mentions a power supply, that he says is OU to start with.  I went and found the exact one he uses, and from the numbers posted, if true, would be correct.  12 watts input and 20 watts output.
Anyway, I have ordered one to have for future experiments, and you have worked more with HV then anyone else that I know, except maybe Moby.  So here is the info if you are interested in buying one and testing it out...They are very cheap!
Specifications: Input: 12 Vdc @ 1 Amp (Suggested power source CAT# DCTX-1215). Output: 2,000 Vac @ 10 mA. Open circuit voltage: 3,000 Vac 30Khz. Short circuit current: 15 mA. UL.
https://www.allelectronics.com/index.php?&page=item&id=HVS-1&index=1
Kind regards,
Bruce
starcruiser
How about this version, I am playing with this one now, need a better HV source than I have, need a NST or two for my bench.
Regards,
Carl
wattsup
@GK
Found this one the other day at my EE surplus place. Had to buy it even though I have no plans to use it yet. I wonder if you can use these backwards. Pulse into the HV side and measure off the Primary side. Will try it this weekend. lol
giantkiller
@Bruce,
I ordered 4 of those xfmrs. I will use ATV batteries for power. Connecting to the grid is no longer viable for future tests. I don't want to pump charges back into the ground side. That runs in parallel to the supply side.
I have watched the Smith vids but if you have a link to the one you are referencing that would be appreciated. That would put us on the same page.
Also on the HV, I found that keeping the current low is mandatory. At least up to this stage it has worked to keep things safe. But as we see in the next pic it can get out of control real fast. Raise the current and added troublesome effects appear.
@Starcruiser,
Per the pic: stage #1 raises the voltages. Stage #2 is configured mobiusly(pancake like operation) so the electorstatic levels are raised again. Mondo with the sparkgap hitting it also. But diminutive if the spark gap is shielded. 90 degree air coupling is at the electrotatic level also. Coler does this also.
But over all item #3 is the raising the current into high electrostatic levels that interface with Aether and that excitation is then coupled into the final output additive to what was put in. This also explains the Earth ground connection. The lamps are put in series with the potential between the sky and the Earth. Basically a short circuit. So that points to the small awg windings creating a large aperture for massive conduction.
But this is a good addition to any bench.
Thanks guys.
