Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
@Nickz, Thanks.
In the vid unit the top and bottom could be the L & M winds. St.Clair used Supermalloy. My suspicion at first was to keep the fields pressed or reflected more into space where the the Bloch wall manipulation happens quite easily as in the Kunel patent. That is why I thought of using Aluminium. Maybe iron wire will work in place of SuperMalloy. Could it be that St. Clair never thought of simplicity and SM could just pull this out of thin air? When SM mentioned bailing wire I associated it with the iron laminations that Telsa harped on in his patents. It worked in my builds for those particular tests.
And in this vid the side winders are really clear and obvious!
That is one shitty build and I give great thanks to SM. Anybody that has prototyped knows the process of getting a process to show, alot of engineering, alot of prototyping, total lack of sleep. Come show and tell time the builder is just glad to use bubble gum and tape to get the demo done. That has been my life as I see it too. When the next stage of money people flock in the idea is to hide the process into a secret.
The SM17 is a close replica of the 'Little TPU that could'....
Now if we refer back to the references of 'Effective Aperture' The center units that are 'off center' in the SM17 shows the process of being 'not quite bang on'. The larger unit would be dealing with more space hence a larger magnification. He used 2 in a weaker area instead of trying to position 1 just before 'bang on'. I still believe 2 frequencies equals just 2 switches. One for each center unit of the same frequency unless two frequencies was another way to keep bang on at bay.
St.Clair Field video:
http://www.youtube.com/watch?v=UewWiUj57gE
NickZ
  @Gk:
      Thanks for the reply.  I know what you mean by the total lack of sleep.  I also hope to find a way to manufacture safe electric power to light my home, run my car etz... and help others do the same, but I don't feel that we have much time left, before the lights go out, and our test instruments won't be of much help.
   As you know there are very few (if any) magnetic power devices that are compatible with a home or office environment, that don't make noise, or upset people close by, or that are portable, and can be moved elsewhere if needed.  That is the reason that I'm doing what I can, to help out with this effort, full blast, sleep or no sleep, come hell or high water.
  As I can see that you and others in the group like to read (understatement), I'll send some information on the mostly unknown and unconventional Vortex Theory. From a source that I'm sure you've never heard of before.  More on that later.
                                            Regards to all,
        NickZ
giantkiller
e2matrix
While following one of the Masters by also waiting in stillness I pondered this concept  ;D
   I've got a big coil of copper tubing about 30 feet long wound in a flat spiral and it's 3/4" diameter tubing.  I thought about running a wire through it with it looped back coming out the same end (bifilar run of sorts).   I'm not sure what I could do with it but it would seem different than winding a wire TPU style around a bigger coil in a number of ways.  And it would not be like coax cable in that it runs both ways returning to the same end it entered.  First thought was to run some 12 guage stranded which has 600 volt insulation (as I've got a big roll of it) on it in this setup but I'm not sure the heavy insulation is what I'd want.  Any thoughts on this odd pancake recipe?
giantkiller
Think about this:
Take two wires in parallel, A & B,
at the pulse end in wire A the field collapses in wire A,
pulse the second wire in opposite direction (at the right time as we push the swing),
this pushes the collapse in wire A increasing the BEMF.
You'll notice in the St.Clair patent the L & M collectors are wrapped the same way but pulsed in opposition. We want to enable a phase and polarity relationship for the two fields so in opposition they work together by the collapse and expansion going the same direction in their path along the runs and perpendicular to the runs.
On a 3 layer TPU the middle run is pulsed in opposition. This pushes the collapse into the top and bottom runs, increasing the collapse speed, like cannonballs.
The minimum layer count is 2 to enable the Bloch wall torsion between the two. This Bloch wall is on the horizontal plane.
Now look at TPUs this way: the runs can be parallel in the horizontal or vertical plane. The space between does not change except in angular placement.
Now lets say we let the middle collapse and use the top and bottom layers to push the collapse. This equates to squeezing the hose!
With sloppy windings and no mass circuitry this is the only way achievable. Woo-hoo!
Also switch or reverse the vernacular of the control and collector coil labels. The collector can wrap at 90 degrees around the control coil so the that the control loop is the bigger winding. The pronounced BEMF creates Radiant energy perpendicular to the control or horizontal coil and thereby sinks to the collector or vertical winding. The same energy that charged doorknobs in Tesla's building multiple floors and rooms away.
Fini...
