Bloch wall disconnect and reconnect. The final design!
Started by giantkiller, October 29, 2009, 02:31:19 PM
giantkiller
No problem...
This is the wave of disgruntlement that appears every so often. You should see the ring pile size of Marco!
Here is one pattern that hasn't emerged yet so let me divulge:
Solid state needs a magamp. Why? A place for the activity to happen, to be stored and used/released. Tubes don't need this. Why? Because the happening, the storage and expression is in the ion/electron field between the cathode and anode. SS doesn't have this space.
Does not the infiinte ring storage have the same parameters as the tube space? Think about that...
--gk. To the victor go the spoils.
wattsup
I think what @otto is referring to is when the mosfet diode reversing speed is matched by the pulse frequency. Also when he says taking off the collector, that is because at high frequency, it is very difficult to separate what is being cause by the mosfet pulse or what is being caused by what is pulsing the mosfet in the first place. If you are using a mosfet to pulse a circuit, then you need an initial pulse on the mosfet gate. Sometimes the whole effect is caused by what is pulsing the mosfet gate. High frequency pulsing tends to be present in the complete circuit especially since we do it with no filtering components because we want the raw power to manifest itself.
It has happened to me many many times. That's why recently I suggested to guys that are doing circuit pulsing take off the negative and see if the same effect is possible although at another resonant frequency because once you take off the negative you change the circuits overall potential.
giantkiller
bolt
Quote from: wattsup on August 09, 2010, 03:52:06 PM
See we keep coming back to this over and over with banging coils.  Its been done now for many years only thing that happens is you get stung on the face and hands from the EMP and headaches. The TPU's never ran like this they started up slow and gently as the frequencies slowly picked up speed. They could be handled without getting whacked and tingled from EMP.
Also lots of discussions about power fets, AMPS, nano second switching times, fast processor clocks handling all the timings. I think you need to remember the TPU was built late 80's long before the vids were even shot. Many years were past before SM had made a few model variants and got them to a stage of showing investors. If SM started off with a tube or two then we are talking about one or two amplifiers or oscillators to generate the frequencies. He already stated for the record there is no mass circuitry.
