New Magnetic Motor Principal?
Started by lumen, November 07, 2009, 01:31:10 PM
lumen
Ok,
I'm not sure that in 150 years someone has never thought of this, but seeing how Steorn is supposed to release their theory by the end of the year, I figured it best to put this idea out there in the public domain in case they are using the same principal.
At least this may leave some recourse for some builders to make devices without restrictions by their license fees.
The bad part is, now that this is posted, they could take this principal as their own and say this is what they were using all along!
Regardless, this is how it operates.
First let me say that there is a way to build an all magnet version but is a bit more difficult. The 3d software does suggest this to be possible based on the same principal and I will show how this could be done later.  For now I will explain the electromagnetic version because this version is the one capable of producing large amounts of power for nothing!
lumen
The layout shows a parallel field created using an array of magnets, however, the field toward the center is more compressed and causes a detrimental condition to exist so this needs to be corrected by either expanding the inner field or compressing the outer field.
More energy can be gained by compressing the outer field to achieve the same density as shown in this layout.
lumen
Now, if you notice the small flat wound electromagnet in the layout, you will see that the field applied is at a point where it is balanced in both push and pull to either magnet face. This means that the coil is not attracted to either magnet set and that is would just set there.
In fact however, it will rotate because it has an applied tendency to twist and this twist is transferred to the center pivot point to cause rotation.
As the coil moves through the field, the field is exactly the same so nothing is changing from the coils point of view. This means that when the current is released from the coil, it will be in the same field as when the current was applied. This means that nearly all the current applied to energize the coil, can be recovered when the field collapses, except for a small amount lost to resistance.
This concept produces a large amount of torque that could easily produce the required energy for self operation.
lumen
Anyone building a pulse motor and recovering the fly back, could easily build the electromagnetic version of this motor.
Those who would like to see an all magnet version should look at the layout below.
Even though a field like the one generated in a single section of the electromagnetic layout would work, a modified field would give higher gain in an all magnet version.
In the below field, a small magnet would start at the point where the field lines merge (just left of the RH set of magnets) , and would be forced to the same point on the opposing magnet set. (just right of the LH set of magnets)
At the end position point the field is balanced and the small moving magnet can be rotated over with no force, and the same torque would drive the magnet back the other direction where it would again need to rotate over.
The energy gained traveling across the gap is far larger than the energy needed to rotate the small magnet in the balanced field so the device will bounce back and forth continually!
gyulasun
Hi lumen,
Would you show one drawing where the magnets are shown with their poles as needed and say if they cylinder or rectangular shaped ones? A drawing just without any flux lines, just with the magnets and its N and S poles.
I am bad at reading/knowing such details from your flux model pictures.
That way I could much better judge your shown setups.
Thanks,
Gyula
