Steven Marks Replication Disassembeled on You Tube
Started by saintsnick, November 09, 2009, 10:33:41 PM
wattsup
@otto
Where do I start. Maybe at the end.
I see you are looking for vibration, etc., but maybe this is not the good way.
When I had my pulse generator working (new one on its way), I built a FTPU mock up, with the two rings, control coils, a center dual coil toroid, a few caps and did some pulsing into it and managed to get the rings to make a vibration.
If I can give you some advice, maybe consider that the closest you can make a FTPU and then concentrate on doing testing with that, this would give you better direct knowledge of the results. Don't get me wrong. What you are doing is OK, but I feel you need to get into the closest known build method of a known TPU and work from there. This is where you may make a new discovery with your oscillators.
I personally am suffering these days from information overload. I had my next plan of attack to do more testing but instead of putting it on paper, I kept it in my head. Then something else manages to come along and pull your attention elsewhere. This is a big problem and it has to do with being able to keep your focus on the task at hand and not always think "well this new info may be better". Yes, what I just said flies in the face of what I am suggesting, but I am just concerned about you and your present situation.
I don't know. During some spare time I will finish my FTPU diagram to the best of my knowledge and observation ability and just put it out there for you guys to consider and or maybe connect the dots, since there is still some unknowns and I am now going to have to concede that even with more hours and hours of looking at that damn bad quality video of the FTPU, I will not get any further then this. That is until there is a better quality video that will pop up one day - soon. hic hic hic. One day soon I hope and I trust. lol
But until then, this will have to do. Give me a few more days and I will post it. I know I have said this a few times now, but to tell you the truth, it is not always fun to do such observations that become tedious, tiresome on the eyes and then you have to make the 3D diagram to show it in a comprehensible manner, and just to get back into "the mood" you sometimes have to give yourself a major "kick" in the ass. Anyways keep well.
bolt
"Doesn't it mean that is looks like an open circuit to the power supply and no power should flow to that circuit ? "
Correct in AC circuits this is called power factor Zero. In RF we can say we have infinite VSWR. In conventional electronics believed we are achieving nothing but nothing can be further from the truth:)
AS RE = RF where we take Power Factor 0 as a total loss is converted to GAIN.
Quote from: forest on November 11, 2009, 09:40:46 AM
My knowledge is very limited but I know that at resonance parallel LC circuit has almost infinite impedance.Doesn't it mean that is looks like an open circuit to the power supply and no power should flow to that circuit ? So HOW it SEEMS to ACCUMULATE power when power source is connected at higher harmonic make&break rate to it ?! :o
This is WHAT I WANT TO ASK EVERY EE on THIS board !!!
giantkiller
From reading Don Smith:
Infinite impedance in the coil equals Zero impedance in space.
Achievable when a spark gap fires into a coil.
My take:
What happens to the equipment in the room when you measure this? Kaboom.
Tesla said 'Men were blown off their feet and died'.
Any other ways you can get this kind energy in a small package with a small 9v battery?
When you ring the primary coil you can then catch copies of that transported energy into many secondary coils with no degradation.
Then channel that into an L.M.D.
--gk.
otto
Hello all,
@forest
the picture is posted in the forgotten thread "Steven Marls secret" page 1.
After almost 40 years in electronics I can also say that Im NOT good in electronics.
99% of the people are connecting their MOSFETs like you did but I never saw something "special" when I had my MOSFETs connected in this way.
In my setup works the IRF 840 and the IRFP 450 because they have the capacitance at the OFF time at around 300pF or so.
@wattsup
tis IS what Im doing. I have 2 TPUs:
a 6" open TPU
and a 6" TPU with a HV coil sitting on top of the TPU with a silver ring....
thanks for the dimensions of that silver ring!
Im working with vibrations because I see that such vibrations are doing a fine job. My oscilators are not good so Im surching for a solution to pulse my coils without oscillators or at least with oscillators that can easily be builded so the people can rebuild them.
You think Im on a wrong path. Hmmm...a little collapse from a 470pF cap is amplified to such a collapse that it fires a coil very high into the air.
Now imagine a lot of such collapses at 2 or 3 different input frequencies.
Or to say it in another way:
this vibrations are kicks. As I have my MOSFETs connected in another, better way, the kicks - vibrations are negative.
My oscillators are only charging and discharging a tiny cap and they are fired into my coils. Nothing more.
Is this a wrong way to build a TPU? I dont think so.
Otto
Tito L. Oracion
Hi everyone gooday  ;D
in most of tesla's work i notice that he only used motors to switch on and off and walla high voltage and high currents are produced. amazing isn't it.  ;D
the simplicity of his works makes him great !
WOW !!!.
including the antenna in the tpu makes produce an input source to a circuit. wow really amazing! ;D
its like a recursion in  c programming repowering itself.
from little caps into big caps discharging in a coil.
little kicks into big kicks.  :D
update in my current tpu:
i'm using ozone patent circuit in my tpu, you know what? its amazing.
