Steven Marks Replication Disassembeled on You Tube
Started by saintsnick, November 09, 2009, 10:33:41 PM
gadgetmall
Its a Trick Light bulb . make your own glass bulb here http://www.metacafe.com/watch/975794/mysterious_lightbulb_hack/
and here http://www.wonderhowto.com/how-to/video/how-to-make-a-magic-lightbulb-271313/
Trick your friends into thinking you got a coil that lights up a bulb with a coil of wire to make contact . Also you can put warm leds in them to make them produce real golden light unlike the one in the video that produces a blue light . As far as multimeter measurements , a Polaroid flat battery and a tiny jt  taped up with the wire and a either a reed switch to trigger it on or a mercury switch . flip it . .
theres even one that looks real and lights up and explodes like theres too much power http://www.youtube.com/watch?v=Df5jx9UUGrE&feature=player_embedded
and as far as all the fancy electronics  you can get 128 volts from a 1 volt Jt and a transistor .
you can also buy them on Ebay  ;)
Gadget
innovation_station
Quote from: Tito L. Oracion on November 12, 2009, 04:03:19 AM
Hi everyone gooday  ;D
in most of tesla's work i notice that he only used motors to switch on and off and walla high voltage and high currents are produced. amazing isn't it.  ;D
the simplicity of his works makes him great !
WOW !!!.
including the antenna in the tpu makes produce an input source to a circuit. wow really amazing! ;D
its like a recursion in  c programming repowering itself.
from little caps into big caps discharging in a coil.
little kicks into big kicks.  :D
update in my current tpu:
i'm using ozone patent circuit in my tpu, you know what? its amazing.
WELCOME ABOARD !!  ;D 8)
IST!
IM VERRY HAPPY TO HEAR YOUR CONCLUSION ..  I THINK YOUR ONE OF THE FIRST TO BRING THIS UP AGIN IN A LONGGGGG TIME ...  ;D
JUST IMAGIME ... WHAT A PROPERLY TIMED AND TUNED IST GATEKEEPER WILL DO ...  ;D  3 PHASE
POWERED BY EXACTLY WHAT GADGET JUST TOLD YOU ...  ;) ..
AND AN ULTRA CAP OF COURSE...
I HAVE GOTTON WELL OVER 500V CONSTANT OUTPUT FROM A JT  SOME SAY IT MAY WELL BE THE SMALLEST TESLA COIL EVER BUILT! ;D
HERE IS A VIDEO .. http://www.youtube.com/user/innovationstation#p/u/6/psRWo7wwtK0
277VDC RECTIFIED AFTER TESLA SPARK.. AA BATTERY..
stprue
Quote from: gadgetmall on November 12, 2009, 07:33:25 AM
Trick your friends into thing you got a coil that lights up a bulb with a coil of wire to make contact . Also you can put warm leds in them to make them produce real golden light unlike the one in the video that produces a blue light . As far as multimeter measurements , a Polaroid flat battery and a tiny jt  taped up with the wire and a either a reed switch to trigger it on or a mercury switch . flip it . .
Gadget
This is a great find Gadget.  This is probably how they did it.
giantkiller
How do you explain the 'White' light in Marco's flat coil with 3 555s?
Quote from: stprue on November 12, 2009, 08:06:49 AM
quarktoo
WOW !!!.
Tesla didn't have transistors to work with and he didn't like tubes. He also used spark gaps for switching.
If you read the ozone patent, you will notice that he states it can be used to create free energy. Ozone + steam = H2O2 which is rocket fuel (hydrogen peroxide)
Stan Meyer made ozone in his air gas processor and Dr. Puhirich also used this method.
H2O2 has a higher viscosity than water and the bonds cleave much easier than water. This is why Meyer called it hydrogen fracturing and Puharich called it molecular shattering.
If you watch the Puharich videos on youtube, you will note that Puharich stated that he changes the molecular bond angle of water from 104.5 degrees to 109.28 degrees from center of mass. That is the bond angle of hydrogen peroxide.
Bond angle of H2O2 - This info. is difficult to find.
http://www.washburn.edu/faculty/sangel/Courses/CH121/Recitation6ans.pdf
http://wiki.answers.com/Q/What_is_h2o2%27s_bond_angle
This might hold the clue as to why Meyer stated he was using red laser LEDS in his ozone generator:
http://oai.dtic.mil/oai/oai?verb=getRecord&metadataPrefix=html&identifier=AD0263364
There are over 10,000 ozone generators patented.
http://www.valdosta.edu/~tmanning/research/ozone/
Puharich also stated in his videos that he was not going to get into the complex aspects of the ceramic in his injector. That is because it was piezo electric and the ceramic probably contained silver which is a catalyst that cleaves off the extra oxygen atom.
Both NASA and the Russians use this to boost space junk. That might explain why Meyer filed an affidavit in the international test report stating that he didn't get information from NASA.
A laser ozone generator (Meyer's air gas processor) is the most efficient method to produce ozone. Meyer's microwave steam generator is the most efficient method to produce steam.
Meyer described the water going to the injector as "ordinary processed water"
The "high frequency / high voltage burst pulse"  going to the injector both ran the piezo to fracture the bonds and polarize the gasses and detonate the gas.
To make a resonant cavity to combine the ozone and steam, a round ball shape is most efficient as it is isotropic meaning it radiates in all directions equally. Tesla stated that starting with the round tank, all things become possible. The WITTS ultrasonic water heater is another example of an isotropic storage probe producing overunity. Talk to a metal spinner about getting the tank fabricated, they probably have the bell shape mold sitting on the shelf already and it only takes them 1 hour to make the two halves.
Tesla was one of the brightest people that ever lived.
