Ionospheric antenna get 5 KW free !
Started by Tesla_2006, March 12, 2006, 07:16:05 AM
triffid
I guess it all helps?
Atmospheric electricity is like a massive photographic flash. An electrical charge is built up, a switch is closed, and electrons barge across a gas, ionizing it and producing light. But a flash is a complete circuit. In the case of the Earth, Ruhnke explained, the atmosphere completes the circuit.
Recent Headlines
December 3: Mars Polar Lander nears touchdown
December 2: What next, Leonids?
November 30: Polar Lander Mission Overview
November 30: Learning how to make a clean sweep in space
Thunderstorm charge generation happens inside clouds. Current flows out of the tops of clouds - blue jets and red sprites may play a role - and connects with the upper atmosphere and the ionosphere. Ultimately, the current returns to Earth through the clear atmosphere. Because it's diffused over most of the globe, it's also quite weak at any given point.
"All three values are very difficult to measure," Ruhnke said. The current is 10-12amps per square meter - "almost nothing." The field is about 100 volts per meter, meaning that the electric potential increases by about 200 volts from the ground to the top of Michael Jordan's head when he's standing still. Finally, air is an excellent insulator, so its conductivity is close to zero.
triffid
Some general info on different types of receivers   http://lep694.gsfc.nasa.gov/waves/instrument.html It might be useful to someone here and its in english.triffid
the_big_m_in_ok
Quote"Practice :* Construction of a passive antenna, the antenna for the novices basic armen"
Okay, triffid:
I looked at the link above you provided and it did load and run like it's supposed to.   I agree with the basic premise of the circuit.   The apparently Castilian dialect Spanish is simple enough for me to comprehend---which is why I understand the circuit.   All Spanish dialects could be like that; understandable to someone who speaks the language.
    As for my precise opinion of the circuit, it's unnecessarily complicated to me.   I didn't get into the article enough to figure out if all those extra components raised the efficiency level of the circuit, as compared to just an insulated wire with a diode to a battery.
That about all I can do now without looking at more pages of the article.
@microcontroller
I know what our Member colleague, triffid, is doing.   He researches information a lot---I do, too---and then posts what he finds.   He and I have been doing that for quite a while on the thread "I see a disaster coming" in the News Forum.   He does this all the time.   Not everyone, including myself, thinks it's bad.   It's a lot of information he relates, but electronic research is the name of the game at OU.com.   He just does it his way.   I'm being honest in my opinion, here.
Carry on, triffid,
--Lee
triffid
MC, I have the time(Im retired).And some electronic background.You have taught me some things yourself.I do stumble around some never knowing where the next breakthrough is coming from.If You have better ideas post them.If I had been able to translate the rest of the spanish articles I would have posted them.We're all in this together.triffid
