0 Members and 31 Guests are viewing this topic.
Quote from: Omnibus on June 21, 2010, 06:20:11 AM
Also, the active resistance of the coil is 11.4126Ohms while the resistance of the metal-oxide resistor is 99.7475Ohms.
Have edited my post with correct data.
If indeed the current goes through the coil then this excess energy is all lost as heat. In other words the presence of the resistor causes this OU. If for instance the resistance was extremely low without changing the other parameters, would OU increase, decrease or stay the same. And in all 3 cases would the average power from the supply go negative? Because now it's hard to tell whether its average is loss or gain. Basically I'm saying how can we change this energy from joule heating to for instance a perpetual LC oscillator.
Omnibus
@broli,
Please bear with me. I'm working towards answering this question. May take me some time so if I don't post here for a while you should know I'm working on this problem.
LarryC
Quote from: gravityblock on June 21, 2010, 02:57:51 AM
Where's my Omni Power?  I want my Omni power, and I want it right now!
Interesting Tidbits #1, Omni Power was named after Ominbus in the overunity.com forum by LarryC.  When you here Omni power today, it is in reference to OU, which means there is more output returned than the input power applied, as defined by the new equation for power measurments that Ominibus shook the scientific foundation and shattered presently acceptable known theories which will re-write physics as it is currently understood.
Interesting Tidbits #2, There is Omni Power (OU) everywhere!
Just trying to add a little humor and to encourage the continuation of this research.  I apologize in advance if this post offends anyone.  It's all about research, observing, analyzing, understanding, and questioning everything.
Nothing wrong with having a good heated debate.
LOL, excellent, thanks GB I needed that.
@Bruce,
The only way to get power out of Don Quixote's device is thru mutual induction, but then all Omni power would disappear.
Regards, Larry
Omnibus
Quote from: LarryC on June 21, 2010, 09:17:56 AM
@Bruce,
Regards, Larry
Slightly funny but you have to work more to achieve you goal of becoming a good comedian. Same as your attempts to calculate power correctly.
LarryC
Quote from: A on June 21, 2010, 09:55:12 AM
Another lie. My goal is not to be a comedian. It is to find OU.
But I wanted to warn you, that the ignorant physicist at the highly regarded Hyperphysics website are spreading anti-Omni power calculations.
Regards, Larry
