Experiments designing a BLDC Acyclical Generator
Started by leeanderthal, January 02, 2010, 07:55:06 PM
leeanderthal
QuoteThe difference with both compared to a homopolar motr/gen is that the magnet poles do not make any changes throughout the cycle on a traditional hp setup. As far as I know. So from what I see, you poles are kinda pulsing when rotating so it can generate due to that if the conductor is stationary and the mags move.
Magluvin,
Very true.  If the setup in experiment #1 would have worked there would have been no pulsing. Do you agree that if the field rotated with the mags in that experiment we would have current?
I have lots of questions about that in another post. I think with the proper design a helical configuration could be made nearly pulse free.
Lee
leeanderthal
Very nice Phoneboy.  I like it.  How about a rotating diametric magnet mounted inside of stationary axially magnetized ring magnets? Sounds difficult to build.
Lee
phoneboy
@ leanderthal, I guess it could work, trying to visualize how the field would flow? Would probably give same problem with what I proposed, you'll need strong rigid supports as the magnets will constantly will be trying to align.
Magluvin
I supopse there is nothing wrong with an alternating current version of the HP. It will have to be tried and tested.
I had an idea that I just did some simple tests on that had individual spokes, each with a diode, and as the mags of a rotor past the spokes would force the charge to only move in the one direction because of the diode, but the voltage was very small if any due to the drop of the diode. The speed of the rotor needed to be very fast. So I put it away till I come up with something better. I also tried the square loop. That needs a full build to see what happens.
But dont give up till you try and experiment.  =]
Mags
Foggy-Notion
Question,
What effect (if any) would conductive A have on the shaft?
With a current going through it?
More drag?  Less drag?
