Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
ramset
Tony
Well said buddy!!
[Did you really have to detox??]
Stefan you need to give Tony moderator privileges in this thread ![maybe Broli too]
Lindsay
Well said also
Chet
Thanks Grandma
agentgates
@broli
Thanks broli as always and you're right. I'll keep these things in mind and try to focus on the project more than other things. :)
BTW, updating things...
1. Pattern generator is ready to run, I programmed it with many kind of patterns, overlapping/non-overlapping, binary patterns (for multiple harmonics). They are each variable in any parameters to each other.
2. I found some junk (10 pieces £1) fet drivers and spent a quite lot time to mess with it in the afternoon. I wont share the details as most of them would be misleading. My well-proven FET drivers are still not here so I ordered some more from multiple sellers to be sure. Until then I can drive only one coil as I found a single last-last-last life saving UCC27322P. I'll try it tomorrow as the junk ones don't make the nice spikes and die after each other.
@Lindsay
Thanks to you too. I think you're also right, time to walk in the nature. :)
BTW, you were who mentioned that you also observed this fast switching thing? It makes me confirm that what we are dealing with is to get the back EMF pulses flow in the secondary rather then coming back to the switching ssd...
Ok, ok, I go to sleep and start with a walk tomorrow... ;)
bullsnbears1
Quote from: CompuTutor on January 14, 2010, 06:32:50 PM
I saw a simple approach to a needed variable.
I threw that idea in in case it had validity.
I was way wrong and wish to retract.
When the idea of two rings is employed,
and you turn them from natural 90 degrees,
It starts to turn "Hourglass" in the center of the side.
The variable I proposed
sadly introduces a second variable one too.
Thank you for catching my omission,
I forgot to state the obvious need
of a retention mechanism of some sort.
There would need to be a fixation mechanism
to overcome the "Sprung" setup...
I'm going to build this. I've got ideas for both of the problems.
I don't need angles any more obviously, but I'm a bit confused about the desired # of windings
psm1963
Jesus, what a load of horseshit this thread is. It should be called Mylow II At least he had videos to go along with his charade, which agentgates has been promising to show and its' been 9 days. Now ambulances and detox and conveniently not sending the unit to Stefan because his ego is bruised. I'll believe it when I see it. It must be some type of mental illnes or craving for attention, perhaps mommy never loved him, but of this I am certain, you have nothing. Go ahead prove me wrong. Oh and I already anticipate all those who have drank the koolaid to attack me for my comments but I have yet to see anything but hot air
agentgates
@ramset
Yes, I had headache, was sick and dizzy. Late last night I went to bed but I had to call them. They took me in and put me on oxygen, got 2 bottle infusions and told them to take me home sometime in the morning. Too many drunks there.
