Solid State Orbo System
Groundloop
Hi Luc,
No problem, just post your result here. It seems to be a related subject.
I did look at the videos and was impressed by the attraction force and the minimum
power needed to cancel the flux. You can make powerful motors with this system.
And if it works in a motor then the solid state will also work.
Thanks for sharing.
Alex.
synchro1
The problem with the Flynn parallel path flux gating is that the coil has to equal the strength of one of the magnets. This takes a lot of power compared to the coils in resonance, flux gating on their own with practically no input. Ossie Calanan demonstrates a metal band doing the job in one of his videos. Perhaps two of these cheap toroid's, one on each end of a coil core, with the magnets inside and the rim glued to the core can be wired in series and achieve tank resonance, cutting input to a bare minimum unlike the Flynn flux directing coil that requires as much power as to equal the strength of one of the parallel magnets. That's a lot of power!
gyulasun
@synchro1
Would you mind reading this link that includes Paul Noel's ideas on how to connect two or more parallel path setups into one other, this way the input power can be minimized and you can get higher input-output separation too:
http://peswiki.com/index.php/Directory:FPPMT:Paul_Noel
from "Parallel Path Backdraft " in the middle and lower down.
rgds, Gyula
synchro1
@Gyula.
Wow! Very powerfull innovation. I need time to digest this. Thank you very much for directing me to that Peswiki article. Paul Noel writes that if the field could be shifted by means of a "Magnetic Diode", something apparently still yet accomplished at the time of his writing, the potential for the generation of power would be limitless. Perhaps the flux shifting toroid might be classified as a "Magnetic Diode"? I'll try and get back to this thread with some additional input in due course.
Bruce_TPU
Here is my idea I would like to test, when my magnets arrive.  Any thoughts on whether it will work as drawn?
Cheers,
Bruce
