Solid State Orbo System
gotoluc
Hi Bruce,
from my tests and understanding a toroid seems to keep most of it's magnetic field inside the core, so I would be surprised it would work better than a standard coil to overcome the PM flux.
I could be wrong though :)
Luc
Bruce_TPU
Hi Luc,
You are correct, and that is why we have the idea is to use the toroid as a make and break virtual switch for the flux.  While the toroid is in the "on" stage, the flux is broken from the "parallel path" and then when the toroid is "off" the flux is able to once again flow.  By simply oscillating the flux, on and off, we create power on the pick up coils.  ;)
That is how it plays out in my head anyway... LOL
Cheers,
Bruce
futuristic
Third version is IMHO the best, but you don't need two toroids only one big enough.
gotoluc
Quote from: Bruce_TPU on January 18, 2010, 01:15:07 AM
Hi Luc,
Cheers,
Bruce
Yes Bruce you're right!... I see that now. Thanks for clearing it.
The disadvantage would be the large air gap between the toroid windings and toroid core :-\  but if the magnets are strong enough the flux will still go through.
Humm, maybe the toroid core could be contacting the laminations and wind in between the open areas.
Luc
Bruce_TPU
Quote from: gotoluc on January 18, 2010, 10:58:27 AM
Yes Bruce you're right!... I see that now. Thanks for clearing that.
The disadvantage would be the large air gap between the toroid windings and toroid core :-\  but if the magnets are strong enough they will still go through.
Luc
Hi Luc,
The pictures are not to scale.  I will be using an air gap of .032"  This will also be the same gap I use between the steel.  There needs to be very small air gaps.  I think I will use tooth picks on their edge, to keep them seperated.
Here is my favorite one, so far,
Cheers,
Bruce
