Solid State Orbo System
Groundloop
@synchro1,
I do not agree with you. The output from the center coil will be sinus like.
Because when all toroids are off then there will be a magnetic field in
both directions in the center core canceling each other out. When I
switch on two of the toroids then we get a field in one direction through
the center core, and opposite when the two other toroids are on. So
by alternating between the two pairs of toroid we will get a alternating
magnetic field through the center core. The core look like this ][ .
Alex.
lumen
@Groundloop
You may have the magnets shown wrong in the diagram?
Shouldn't it be N and S at top and N and S at bottom?
Bruce_TPU
Quote from: synchro1 on January 18, 2010, 04:18:25 PM
@Bruce,
Nice work! I realized that all one need to do is to increase the diameter of the middle disk neos between the toroids, to equal the strength of two stacks on each side and allow for the space needed to fit the toroids in between. Also, based on Paul Noel's idea of "Backdraft", it would be possible for the first air gaped armature to act as a middle magnet for a second larger parallel path apparatus, now coupled to a T shape, providing over ten times the flux force in the larger armature coil to one side. I also noticed your schematic has the second unwound armature on the other side. That one has to leave. The amplification of force by this kind of coupling presents a real solid chance to go overunity.
snip
Hi Synchro,
Is this now correct??   ???   Please ignore the flux lines...I will redo them later.
Thanks!
Bruce
4Tesla
Alex,
I like your idea!  I'll follow this thread closely.
4Tesla
Bruce_TPU
@ Synchro,
In this last picture, I have added the T.  Did I do it correctly and are the magnets positioned correctly, etc..  This should give the Ten Times multiplication of the flux, correct?
This is the one I will build, if it is correct.
Thank you,
Bruce
