Solid State Orbo System
Bruce_TPU
Quote from: Groundloop on January 06, 2010, 03:00:01 PM
Bruce,
Take a look at the attached drawing. In this setup we use two toroid cores at each end.
Then we use a magnetic crossbar at each ends of the magnets. Now, when the toroids
are off then the magnetic field will take the shortest route in a closed magnetic field
at both ends.
Now we switch on the two top toroids. The magnetic field will now go through the center
core instead because that will be the lowest resistance for the field. We switch off again and
now we switch on the other two toroids. Now the magnetic field will travel through the core
in the opposite direction. We switch off again, and then repeat the sequence. This will create
an alternating magnetic field in the core and we will have a lot more power out in the generator
coil.
Is there anybody that have the FEMM simulator that can try this setup?
(Or other magnetic simulator that can simulate this setup.)
Alex.
Alex,
I LIKE that idea...a lot!  I think it will indeed increase the output.
Do you have the means to test it?
Cheers,
Bruce
Groundloop
Bruce,
Yes, but not right now. I have to order more enameled copper wire first.
So it will take some time. I hope that some other member can do me a
magnetic simulation before I build this stuff. A magnetic simulation will
give value information.
Alex.
Staffman
Groundloop
I'm building the circuit right now as a test before I get the PCB from gotoluc (Thanks Luc!!!). I'm hoping that the transistor used can be substituted for a NTE284 (bipolar npn). I'll let everyone know if I let the smoke out of it. I've had to make a couple of diode substitutions. For D5, I'm using a 1N4007 and for D1/D2 a 1N4002. I hope they will work out. Someone let me know if they will not work.
It's going to take a day or two for me to find some toroids and wind them. I probably need more wire too. I have an old pc power supply that has some toroids in the them, but not the size specified. They will probably work, I'll just have to adjust the magnetic field and windings a bit.
Back to the grind....
Groundloop
@Staffman,
It is great that you will build this also. More people testing will get faster results.
May I recommend that you hunt for the Ferrite tubes that you will find on mains
cables to switch mode power supply (laptop supply etc.) They are great for
the generator coil. You need a little length so that the generator coil can hold
some wire.
The inductive voltage kick back can be brutal when you switch the
toroid coils. The NTE284 is only rated 180 volt. If you can find ANY NPN type
transistor rated 800 volt or more then you will be safe. You can also use a mosfet
rated for high voltage. Go for the above 500 volt N-Type mosfet. My recommended
type for the PCB is the IRF PF50 (TO247 size).
The diodes in the 555 switch is NOT critical at all. You can use whatever type you have. 1N4000,
up to 1N4007, 1N4148 etc. will do fine.
But if you use a bipolar NPN transistor to do the switching then you need
to use the 1000 volt 1N4007 across the collector and emitter. If you use a high voltage
mosfet then you can omit that diode because the mosfet already has an built in diode.
Groundloop.
tadejstenta
Groundloop,
and all
I will not explain that I do not have a lot of knowledge, but
My thinking is, why spend energy for shielding magnets, if you can (energy) used to generate the magnetic field (electromagnet).
excuse my ignorance, but what would be the energy consumption if it were on both sides of the electromagnet of the generator, instead of magnets which must be shielding.
and the question of whether the same effect?
sorry again, but I realized it when I read this topic that can be a kind of link or similar principle as in the MEG generator.
tommorow I`ll give a shot and try to replicate groundloop`s generator in my garage, I`ll just use coils and magnets from my "orbo wheel" (it`s past midnght here)
sorry to my english (I never learned in school) but I vrote this text with help of google translate.
regards, Tadej
