Solid State Orbo System
Bruce_TPU
Hi Alex,
OKAY, I think I have figured out how to add EIGHT more output generator coils without adding any more toroids!!   :o
Let me know as soon as your hexfets come in and we can test the idea with one coil...and if it works for that one (and I think it will!)  It will work for the rest!  That would give us a total of ELEVEN output generator coils
I don't want to tell the idea until you can actually test it...!  Anticipation...LOL
Cheers,
Bruce
Groundloop
Bruce,
Make a drawing and post it here. :-)
Alex.
futuristic
Perhaps you could try this one:
Bruce_TPU
Quote from: Groundloop on January 08, 2010, 02:34:47 AM
Bruce,
Alex.
Hi Alex,
Okay, I am absolutely convinced, that the first test will show positive...because the magnetic flux does not "see" what we see, I realized that the field lines will flow to the edges of the toroid, from the magnets, and when the toroid is switched on, boom, field lines are no longer attracted and then toroid is switched off and power is generated in our coils!  Just because there is no hole, should NOT matter.  (I hope!!  LOL)
The first picture is of the test, with two coils!  If that works, all EIGHT (second picture) can then be wrapped and added!!
Cheers,
Bruce
Groundloop
@futuristic,
Thank you for your contribution to this reserch, and welcome to this thread.
Good ideas are always welcomed.
Alex.
