Solid State Orbo System
Groundloop
Bruce,
Great idea. WoW, this generator can really grow to a monster in a short time.
I will test the 90 degrees method and report back soon.....
Alex.
Groundloop
Bruce,
I have tested my small coil at a 90 degree angle to the toroid, and guess what,
I T   W O R K E D ! ! !
Attached is my idea. Use a toroid tube at some length and we can fit as many
generator coils as we want.
Now we need to start building.
Alex.
futuristic
This scheme got me thinking that you could actualy put cylindrical or ring magnet with radial magnetization iside of toroid.
This would make shorter magentic paths and stronger magnetic field. ;)
But in this case you would have to remove two generator coils that are symetrical with the hole of toroid and only use x number ob those that are positioned 90 degrees to the toroids hole.
Groundloop
@futuristic,
Yes you are correct. But where to buy tube Neos that have one pole at the outside
and one pole at the inside? The toroid tube can be made by stacking several toroids
and then wind the copper wire onto all of them at the same time. That said, I have
found that we do not need a extra strength magnetic field. The magnetic field must
be just strong enough so that the toroid is able to switch it off.
Alex.
Bruce_TPU
Quote from: Groundloop on January 08, 2010, 06:25:53 AM
Bruce,
Alex.
A W E S O M E ! ! ! !
Hi Alex,
I like your idea, just remember, the larger the toroid (cylindrical or diameter) the more power we will need for the effect!  But Y E S, a Cylindrical toroid of A N Y size will work!
Add all of the coils, Alex, and then let's work on efficiencies with your proposed circuit, powering the toroids at their resonant frequencies.  I also have a great idea for increasing dramatically each of the efficiencies for A L L of the generator coils! ! !
Cheers,
Bruce
