Pulsed DC Transformer with Embedded Magnets
Started by ltseung888, February 24, 2010, 03:55:56 AM
0 Members and 114 Guests are viewing this topic.
ramset
Itseung
Quote:
Can someone recommended a Pulsed DC source?
Buddy the way I see it,
Its All in the "pulse" and its "Tricky"
Chet
Thanks Grandma
ltseung888
Quote from: Schpankme on February 26, 2010, 02:24:41 AM
ltseung888,
How does your Lead-Out Energy differ from that of Nikola Tesla Radiant Energy?
-Schpankme
Extract from   http://www.nuenergy.org/alt/tesla_energy.htm
Brooklyn Eagle July 10, 1932 Nikola Tesla states:
I have harnessed the cosmic rays and caused them to operate a motive device. Cosmic ray investigation is a subject that is very close to me. I was the first to discover these rays and I naturally feel toward them as I would toward my own flesh and blood. I have advanced a theory of the cosmic rays and at every step of my investigations I have found it completely justified. The attractive features of the cosmic rays is their constancy. They shower down on us throughout the whole 24 hours, and if a plant is developed to use their power it will not require devices for storing energy as would be necessary with devices using wind, tide or sunlight……
The Lead-Out Energy theory is much simpler.  We WILL not violate the Law of Conservation of Energy if our machine can Lead-Out (or bring-in) energy from the surrounding.  One good example is gravitational energy.  If you pull a pendulum horizontally, the pendulum bob will rise.  The basic physics laws state that:
Horizontal Work or Energy Supplied = Horizontal Force x Horizontal Displacement
Vertical Work or Energy Supplied = Vertical Force x Vertical Displacement
If you work out the example of a 10 unit of Force pulling horizontally on a 60 unit weight (vertical force), the ratio of horizontal Energy/vertical energy is roughly 2:1.  This implies that we can supply two parts of horizontal energy and lead-out 1 part of gravitational energy to use.
The pulled pendulum is not a very efficient machine.  Theoretically, we can use copper wires and let it swing in a magnetic field to extract the Lead-Out Energy.  We then pull it again at the right time to lead-out gravitational energy again.  The more practical way is to change the oscillation motion to a rotational motion.  Also change the gravitational field to magnetic field.  Instead of the mechanical pull, we use Electromagnetic pulse.
In our patent application, we stated that energy can be lead-out via suitable pulsing.  In the Tong Wheel, we used Pulsing Coils to drive magnets on a rotor to lead-out gravitational and magnetic energy.  In the FLEET, we use flux changes to lead-out magnetic (electron motion) energy.
Details are in the Lee-Tseung Lead-Out Energy thread.  I shall write a book to describe the full details.  The decision is to have an easy to demonstrate and inexpensive working prototype to accompany the Book.  The Tong Wheel is too expensive and too bulky.  The FLEET may be the right answer.
Lawrence Tseung
Director
Help Seedlings Innovate Foundation Limited.
Paul-R
Quote from: ramset on February 26, 2010, 03:29:47 AM
Itseung
Chet
A pulsed DC source should be cheap. I think all we need to drive the Fleet's input coil is a 555 with attendant components, with the output, pin3, feeding a transistor between a battery and the input coil.
Can someone sketch this out with components and values?
(providing for a wide range of frequency and input voltage)
Paul-R
Quote from: ltseung888 on February 26, 2010, 12:45:18 AM
Simple variable frequency oscillator
This is a very simple circuit utilizing a 555 timer IC to generate square wave of frequency that can be adjusted by a potentiometer.
This is good but I think we need to be able to use it to switch a transistor
to supply a better voltage and power level. I don't know how much the 555
can give on the output pin, but it won't be very much.
Schpankme
Quote from: ltseung888 on February 26, 2010, 05:00:26 AM
The Lead-Out Energy theory is much simpler ... we use Electromagnetic pulse.
Lawrence Tseung
Director - Help Seedlings Innovate Foundation Limited
ltseung888,
It's unfortunate that your reinventing the wheel, that Nikola Tesla described in great detail over 100-years ago; and to be self-serving, you have renamed Tesla's Patented Work on Radiant Energy to something ridicules called Lead-Out-Energy (i.e. to Lead a horse to water or Lead Acid Battery).
- Schpankme
"Lets play follow my leader!" - Blue Thunder 1983
