Electrical igniter for gas engines A keystone to understanding by Magluvin
Started by Magluvin, March 01, 2010, 01:30:50 AM
ramset
delboy
Seems like we are talking about two different things
1. A set of contacts points[switch].
2. A spark gap [way to maintain pressure /control other aspects of the circuit]?
Well you are saying a spark gap is a "big" mistake for #2 .
Seems like you have accomplished something special,a lot of what you are saying 'Rings true".
So you are saying the supply doesn't "feel" the one wire "Tap"?
"If the supply doesn't "know" the tap is there,how can it ever be charged for withdrawal?"
Or is it more like the supply becomes so "huge" the withdrawals are a pittance?
You are doing this with 'Time" and "pressure" and Harvest[tap] ?
This is hard to get the brain around , I suppose that is why we don't have it yet?
Although it sounds like you do![and this guy-> ;D ]
Chet
Ps Tito says its easy once you Know how.
This part ->  FOR THE BENEFIT OF MANKIND!<-
Is the best part ,and the "Only" reason I'm interested.
Thanks Grandma
Goat
Hi all;
I've been looking at Tito's circuit that was mentioned earlier, I'd like to try it but I'm having difficulty in figuring out the values of the components and the way things are drawn and explained in the notes..any feedback would be greatly appreciated....the way it's written is that:
The relay acts as a vibrator switch
For every cut of the secondary coil the collapse produces high voltage
Reverse diode is used to direct the flow back to the battery
Like half wave battery charger
Caps and diodes to protect contacts
Primary of transformer is also used to charge the battery
Resitor...?
Transformer: 220V Secondary, 24V Primary
Questions and Comments:
Notes of drawing on transformer say "Transformer used in reverse"
Is what is pictured in the schematic and labeled as secondary the 24V side of the transformer or the other?
Where is the Reverse diode?  If it's missing in the schematic would it go on the wire from the full bridge rectifier back to the battery?
If you had a 12V relay hooked as a vibrator and the contacts became stuck would placing a fuse on the line to the battery be good enough of a safeguard to prevent a short circuit?
What values of the components would be safe to use?
How big of a transformer do you need?  One from a Microwave or larger?
Any comments and suggestions welcome.
Thanks
penno64
Hi Mags,
I have located and read Pat No. 609250.
Sadly, I am not seeing what is exciting you.
I admit that my understanding is not at all good, and I would appreciate some clue or hint as to the
goodness of this patent.
Kind Regards, Penno
Tito L. Oracion
Quote from: Goat on March 03, 2010, 03:30:00 PM
Hi all;
Resitor...?
Thanks
hi goat goodday  ;D
many in youtube are doing it now
just forget my circuit ok?, what i really want to do is just something like this at that time ok: and that is a long time ago:
http://www.youtube.com/watch?v=BJi4tSz8_j0&NR=1
http://www.youtube.com/watch?v=-wJqMDCsXus&feature=related
http://www.youtube.com/watch?v=_TjxV3c7pTo&feature=related
very simple and easy to do ok.
just want to add this is interesting!
http://www.youtube.com/watch?v=LmY3iAKJKXc&feature=related
http://www.youtube.com/watch?v=4-4cd7LEPfc&feature=related
this one will answer some of your question watch this is good:
http://www.youtube.com/watch?v=AUdrEhFxOM0
include this for quiet version
http://www.youtube.com/watch?v=u82tBke0sp4&NR=1
sorry i'm tooooooo lazy   ;D
otits  ;D
ramset
Thanks Grandma
