Self running coil?
Started by gotoluc, March 13, 2010, 12:40:57 AM
gotoluc
Quote from: mrock on March 18, 2010, 12:37:59 AM
Edited & Compacted
Thank you mrock for making the changes.
Luc
Quote from: NextGen67 on March 18, 2010, 12:39:52 AM
And the 24 mm should be .24 mm? (actually .255 including dielectric layer?)
NextGen67
Yes NextGen67, you are right!
@mrock can you change it to 0.25mm instead of the 24mm
Thanks
Luc
mscoffman
Quote from: gotoluc on March 17, 2010, 08:31:23 PM
To whom ever it may interest. I received the below message by
YouTube PM from user: energytruth's who I believe is OU user:
PaulLowrance
Is this him?...  if so, what's up with him ::)
Luc
Take it to University
A quick easy way to tell a faker is they refuse to take it to University or
someplace and all they do is chant to theme, "Please build it. Just build it.
Please build it!" So far you've encouraged people to build it, but have made
no mention to you taking it to a University or anyplace to have it verified by
professionals. If you're a faker to distract from the Steorn replications, you'll
be caught one day. Promise You! There are methods you can't even begin to
imagine. Getting compensated to lie and distract the public is against the LAW.
@gotoluc
If you want, you can go to his blog and ask him what he means.
He is doing some very advanced technical stuff himself.
http://globalfreeenergy.info/
I'll tell you, I expect he'll deny he sent this. Mainly cause it makes
no sense. ;). He seems to be a very smart guy but he has said some
emotional driven things in the past. He also seems to have a relatively
intense adverse hacker following that damages his web site etc.
And they are taking stuff he said previously and broadcasting it...So
please, if you will, don't add to it.
gotoluc; it's important that you don't listen to adverse things sent in
the way of the above message.  You are contributing greatly to the
general knowledge level with your videos of hands-on experiments
...Force anyone else of them come here and be reasonable!
By the way, let those who want to patent motors with no outputs
do that all they want...they are the ones that are their wasting
time. Who first uses scientific and engineering principles?
:S:MarkSCoffman
gotoluc
Quote from: NextGen67 on March 18, 2010, 01:55:06 AM
@Luc,
You mention in the video that while the Cap is charging, you constantly need to re-adjust the frequency of the generator slightly. That means the Cap is influencing the coil behavior... Is there a way to collect the energy in the Cap, but exclude the cap from the from the rest of the circuit? Or just try to place the cap (or another one) at a different place in the circuit and by such avoid any possible leaking at all ?  Maybe a simple diode could allow a one way only energy direction to the Cap.
NextGen67
If a variable resistance is added on the cap bank and the resistance raised to the point where the voltage does not climb or go down then no adjustments would be needed.
Luc
mikestocks2006
Quote from: gotoluc on March 17, 2010, 05:11:15 PM
Hi everyone,
I took some time off today to do some more experiments as I can't stop thinking about this setup and I'm sure that goes for many of you.
I made 2 new video's to which I hope will answer some questions and help understand the effect.
Sorry I can't answer individual questions. I rather use the limited time I have to continue experimenting and posting videos that will hopefully cover everything one would need to make a successful replication.
@Gyula, can you please explain how the 3vpp measured gate leak between the source and drain is capable of keeping the circuit running NOW at 30vdc, 57KHz with 50% duty cycle without using any current and maintaining 1.90vdc on the pickup coil with 49,850 Ohm load. Thank you for your help and time
Test 5 video: http://www.youtube.com/watch?v=RhrYzBld74w
Test 6 video: http://www.youtube.com/watch?v=UflGpzijWIA
Luc
Hi gotoluc,
In searching for explanations, there could be another remote possibility, may I suggest the following very simple test?
Remove the probes of the two mutlimeters that continuously monitor the voltage and current of the capacitor(s).
And then, only measure the voltage/current momentarily at some time intervals eg every 10 or more  minutes to see if the voltage still rises.
IIRC There was another thread, I think Ossie’s motor, or orbo replications, where it appeared that a trickle current from the continuously hooked up voltmeter was back charging the source battery…
Btw what are the batteries used in those two meters? Are they 9V a piece?
Great work and thought process on your setup
Thanks for posting.
Mike
gotoluc
Quote from: gyulasun on March 18, 2010, 10:38:12 AM
Hi Luc,
To clarify the two coils winding details even better, let me say:
The start of the left hand side coil is at the 11:30 clock position and its end is at 6:30 ,ok?
The start of the right hand side coil is at the 5:30 clock position and its end is at 12:30 ,ok?
AND both coils start by going UNDER the core first, ok?  (AS shown by you and by HarryV too.)
HOWEVER on the schematic made by member mrock (Reply #92) the start of left hand side coil is drawn as going OVER the core first, not UNDER the core.
WHICH IS CORRECT?
Thanks, Gyula
Hi Gyula,
the changes made by mrock are correct! as I asked for these changes. Please see this post as this maybe important until proven otherwise: http://www.overunity.com/index.php?topic=8892.msg233097#msg233097
Luc
