Breakthrough with the Anton HHO cell !
Started by hartiberlin, April 25, 2010, 02:33:30 AM
Omnibus
Quote from: briansahern on April 30, 2010, 09:12:13 AM
There has been a lot of confusion with regard to Brown's gas properties. I obtained a unit made in Outer Mongolia and thoroughly quantified its operation in 1995.
1. the efficiency of electrical energy to stored chemical energy in H2 + O2 gas was 87%. It had 60 parallel plates acting is series with 120volts each section acting as a 2volt cell. The system ran at 6 Amps
2. The gas evolved is stoichiometric (2H2 + 1O2)
3. The mixture is highly dangerous and prone to explosions when stored in vessels of large crossection.
4. Storing the gas in  small diameter tubing results in implosions and creation of a partial vacuum. This is because water will condense as a liquid on walls if they are close enough and the liquid occupies only 0.1% of the volume of the gases. In a large container too many reaction occur before condensation occurs.
5. Running an engine on Brown's gas is not routine. The dilution with air is necessary fro smooth operation.
6. All the mysterious properties attributed to Brown's gas, such as melting tungsten are simply combustion processes as tungstean wants to be W2O3
7. There is no magic to Brown's gas. Brown was a 'showman' and had to keep moving.
8. That does not mean that the high voltage electrolysis cannot support over-unity energy production.
Thanks for the explanation. I was just going to ask you how this all happens.
As for the OU through electrolysis of water, it can be done even at low voltage electrolysis but for completely different reasons than the ones that are being discussed here. I even have a patent, which has probably expired already (I don't care about patents but was forced to file for one back then by the institution I used to work for ... those were the days ...)
Now, this new aspect of obtaining a gas with much higher energy efficiency than expected is quite interesting and it has nothing to do with the known electrolysis, if what the German scientists are showing is real. That cannot be achieved by the 87% efficiency mentioned by you. Like I said such gas has to be studied calorimetrically to confirm that it really has the properties claimed. Demonstrating a self-sustaining device is even better but it should be done convincingly without the excuses with Chinese cheapos and stuff.
vrand
Quote from: Omnibus on April 30, 2010, 08:10:21 AM
See, the sitting on the chair and seeing the car move are the conclusive experiment in your example. On the contrary, in our case here we're not sure if we're dealing with a real phenomenon at all. So, it's not about understanding how it works but whether or not it's just a trivial mistake due to errors in measurement. That's the problem. Proving that it's a real phenomenon in this case isn't as easy as sitting in a chair or turning the ignition key. It doesn't consist in just building those machines. To prove OU or radiation elimination is more involved and that cannot be accomplished by first manufacturing devices and selling them to customers, as in the case of making chairs. The powers that be will immediately use the disgruntled customers to shoot down the research (cf. Perendev). These powers aren't shooting down failed-to-deliver Tokamak or the failed-to-deliver five billion dollar laser fusion project but they will certainly shoot down promptly any OU project at the tiniest opportunity. Therefore there must be iron clad proof that the claimed OU machine is real before setting up a company to sell it to customers the way you have to have a car that moves when driven in order to offer it on the market. Like I said, that isn't easy and hasn't been done yet to satisfy the rigorous criteria of science. Most of what we're seeing are attempts in trying to woo investors with elaborate games based on questionable presentations. Genuine efforts to show quality research openly and competently are a rarity and have not amounted to much so far in convincing those in the know of the validity of the claims.
Sorry to disagree with you  ;)
Technology adoption lifecycle
Beal, Rogers and Bohlen together developed a technology diffusion model[5] and later Everett Rogers generalized the use of it in his widely acclaimed book, Diffusion of Innovations[6] (now in its fifth edition), describing how new ideas and technologies spread in different cultures. Others have since used the model to describe how innovations spread between states in the U.S.[7
The report summarised the categories as:
- innovators - had larger farms, were more educated, more prosperous and more risk-oriented
- early adopters - younger, more educated, tended to be community leaders
- early majority - more conservative but open to new ideas, active in community and influence to neighbours
- late majority - older, less educated, fairly conservative and less socially active
- laggards - very conservative, had small farms and capital, oldest and least educated
http://en.wikipedia.org/wiki/File:DiffusionOfInnovation.png
The famous "Bell Curve"
Anybody who buys something new will fit on that curve.  BTW how does one post a photo in a post on this forum?
I am firmly in the "innovator" camp  ;)
No disrespect, but would I categorize you as a "laggard," very conservative, only buys something when all the proofs and theories have been ironed and the product is well established in the market for years.
Best regards, Mike R.
Omnibus
I know that theory favored by many libertarians (recall, Gene, a former registered republican later converted to libertarianism). That applies to technology and other utilitarian stuff, not to real scientific innovations. The true revolutions in science that change the world don't work that way. The reality of the effects must first be rigorously proven and only then it can find its way to the market and whatever else. Market is secondary to the true innovations.
vrand
Quote from: Omnibus on April 30, 2010, 09:54:13 AM
That China genset is actually pretty efficient, as it is an OHV ICE  ;)
They showed a running engine and powering a load, while also powering the Anton cell. To me that is VERY convincing.  They now need to make it stable so one man can operate it and show longer operation run powering a load.
A typical natural gas regulator should work. There are kits that one can get off the internet for small ICE's.
vrand
Quote from: Omnibus on April 30, 2010, 10:29:11 AM
Lets agree to disagree  ;)
My new signature on this forum  :)
“A new scientific truth does not triumph by convincing its opponents and making them see the light, but rather because its opponents eventually die, and a new generation grows up that is familiar with it”
Max Planck
