Working Air Battery
Started by lasersaber, June 08, 2010, 11:39:33 AM
Bizzy
Quote from: b_rads on February 22, 2011, 10:13:32 AM
Good morning Bizzy - very impressive!
See below for the PVC we talked about yesterday.  I was out of conduit so I used threaded rod instead, I much prefer the conduit.  Let's share numbers: Open circuit voltage for two cells (2.25v).
Voltage with load (1.5v).  Amperage while running fan motor (165ma).  I would think your amperage would be higher.
Keep up the good work!
Brad S
Hi Brad
You have a very nice set up yourself! I hope to test your wire idea versus my copper tube design either today or tomorrow. So we can start comparing our results with a less variables.
As afar as amps goes I do know I am producing more just by the fact that I am using magnesium and carbon but like I mentioned I don't trust my readings enough to actually post them yet. I'll just say that it is not in milliamps. :)
Bizzy
b_rads
Quote from: Bizzy on February 22, 2011, 11:10:48 AM
Bizzy
You've got me excited.  I am not very confident in my reading sometimes.  When I doubt my readings I use 2 multimeters (1 analog, 1 digital) for verification.
Bizzy
Quote from: b_rads on February 22, 2011, 11:41:57 AM
You just reminded me, that I have an analog ampmeter on my alternator testing table. With a little rewiring I may be able to use it it to double check my amp readings on my multimeter.
merci vielmals
Bizzy
guruji
Hi Bizzy and B_rads very impressive work you've doing nice nice. Is Charcoal same as carbon?
Thanks
Bizzy
Quote from: guruji on February 22, 2011, 03:21:08 PM
Thanks
I beleive that charcol is a source of carbon but not very good. Coal would be a better source of carbon and have been experimenting with that in my earth batteries before the snow arrived.
Bizzy
