UFO propulsion theory....
Started by infringer, June 17, 2010, 11:21:40 PM
giantkiller
I put 620hz, 630hz, 12khz into gnaural2 as 3 base frequencies.
I will also put this into my 3 frequency control system tonight and scope it.
I will also put this into my Sound Heterodyning Interference Transmitter (trinity device). I need to add a line out muxed with the 3 channels for larger audio and driver output amplifiers.
So far in Gnaural2 I like what I hear. Listen for 5 minutes then shut off and there is a tiny, tinny echo after short sounds in your hearing.
I muxed the 3 square wave freqs into one output and scoped it. The 12khz shows up in blocks that move slowly from right to left. Precession. Same would happen with sine waves.
angryScientist
Back to the future; Flux capacitor. Yes it is a misnomer. Yes you are biased. Yes they are two different concepts created in two different way. Yes I am VERY board with the nonsense that has been offered by the general population (You).
Combine the two concepts (Flux, Capacitor). According to theory, what happens?
I'll even throw in some explanation for the nincompoops; Electric charges move in an electric field. A magnetic field deflects a moving charge. (Think AC.)
Tesla is rolling over in his grave and so is my Grandpa (Yes, he was a professor.)
angryScientist
Excuse me. Tesla was actually a doctor.
giantkiller
Quote from: giantkiller on June 29, 2010, 06:08:55 PM
Channel 1 = 620hz
Channel 2 = 630hz
Channel 3 = 12khz
Travel direction on scope is right to left.
Tonight I flip the channel 1 and channel 2 signals to see the directional change. Should have done this at the test.
This thread could use concrete examples of using theory to execute testing the prove theory to move to fact.
This talk of spinning is the same effect of what is mentioned with the negative / postive flux intertwining.
infringer
well we cannot doubt the hutchinson effect...
Sound is proven to levitate objects without a doubt...
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
