These magnet wheels look set to run !!!
Started by Raj Balkee, July 10, 2010, 07:06:29 AM
Raj Balkee
Hello Thay.
The diameter of the outer rim of the inner small wheel IS HALF the length of the diameter of the inner rim of the outer larger wheel.
The magnets will be the biggest and strongest available.
I am indebted to you for having a go at a build and test of concept.
Many many thanks.
Regards.
Raj
Raj Balkee
Quote from: Thaelin on July 18, 2010, 01:32:29 PM
Hi Raj:
   Going back to the new draw in post 5, if you follow all the lines you have drawn, you will see an "exact" replication on each side. That is to say, you have an equal attract and oppose on each site. This draw is in total lockup as shown and will not move.
   On a better note, KJMag has 3/8" diametric magnets for about a buck apiece. So for about $25, I can have some fun too. Need to order some big diametric anyhow. Keep ya posted. See how many more blisters I can get in the process.
thay
AS WE WOULD EXPECT, I presume thay must be suffering from blistered fingers from his trial build, for not coming back here ...
I thank thay for caring/daring to try.
I suspect I would be full of blisters too, by new year, when I shall try my build of my AGE concept.
Raj
Thaelin
   A couple of pinches yes, no blisters yet. You are quite right. I am having a hell of a time getting them to orient right and not spin around while setting. The only thing I can come up with is setting them in an insertable section and then pushing that into the wheel with glue. Just nothing here to grasp while inserting. I think it may be more adventagious to get another 24 and make this twice as big in size. The rings are no problem to make and drill, just getting the pole faced the right way.   ;D  Sure glad I didn't try with 3/4" size.
thay
and by the way, I am still working 6 days a week.
Raj Balkee
Hello Thay!
How are things fairing with your trial?
I am closely following all magnet concepts and devices posted on this forum, and I find my AGE concept has a distinct difference from all.
My concept uses two forces:
(1) the repelling and attracting force of magnets to overbalance the wheels to make them turn.
(2) the force of Gravity to reset the unbalanced wheels.
Both forces are expected to act simultaneously, to make both wheels turn continuously.
It would be nice to know if Thay can find any indication anywhere near to my concept.
Raj Balkee
I omitted to point out that my AGE concept is 'patent pending'
Patent Apllication Number: GB1008778.1
Filing Date: 26 May 2010.
Raj
