The downfalls of conventional electrolysis - and how to fix them
Started by oswaldonfire, July 20, 2010, 11:30:31 AM
LtBolo
Wow. Gee. Thanks.
Yes I read it, sir, and yes I was aware that it didn't show magnetolysis. Since you presented it as proof of technology that somebody should be pursuing, I was simply allowing the possibility that I had missed something meaningful. Nails and acid isn't exactly newsworthy.
I applaud Chris' efforts and I wish him well.
Since folks would rather attack me than have rational discussions, I will leave. Good day and good riddance.
passion1
Quote from: Airbag on August 05, 2010, 05:16:36 PM
Two Questions:
At Reply #191, In the picture of a unit that was used/built by Alaskastar himself, what is the coil around the lower inlet fitting ?
Airbag
Funny enough I asked Alskastar the very same question at the time.
That lower few windings means nothing and is merely a few windings to keep the main coil in place so that it does not unwind. Remember its just one coil.
By the way:
The reason why I personally terminated my experiments in 2008 is not because I questioned Chris' credibility. Initially I was just as excited about the concept hoping that it was 'The Solution', but after working a lot with this really nasty saturated NaOH/KOH concentration, I started asking myself how viable this solution would be in practice.
Even if one get this to work, and eventually get an engine running on it, what happens if the vehicle is in an accident? Could one safely with 100% certainty prevent this solution from spilling? What is the legal implications if the solution spills and anyone gets hurt? This is really vicious stuff....
The saturated NaOH/KOH is >100 x stronger than the concentration typically used in 6 series cell hydrogen boosters and people are already complaining about a typical weak NaOH/KOH solution saying its "not ideal/dangerous".
(Note that I have built several 6 series cell boosters and I am not scared of using NaOH/KOH, but there is a BIG difference between using a few teaspoons of NaOH/KOH in a liter of water compared to a saturated solution!! And anyone that think I am exaggerating clearly has not worked enough with it yet...)
Not trying to be negative, just being realistic and sharing with you the reason why I personlly did not continue experimenting after my initial tests.
If anyone of you can make it work, I would be just as excited, (at least you should be able to use it in stationery installations) but still the implications of the saturated NaOH/KOH solution is in my opinion the BIGGEST real-time implementation obstacle.
ramset
Fellas,
A lot of good points and observations from "ALL"
The biggest  one
DO IT!!, Try it , SHARE what you try .
I will .
And yes its Nasty
The list of "Nasty" in our every day lives Starts with the kids dirty diaper  passes Fiddo's flea collar and goes up and off the nasty scale, flying right past your coffee cup in the Microwave and God knows what else!
Be safe with the "NASTY"!
It makes the "MAGIC" happen!
Chet
PS
Stihl Woody
Any bubles in your "bath"?
Thanks Grandma
ramset
OK,
Getting the "NASTY" containment vessel ready!
The lab assistant [smoosh] is being awfully quiet!
I don't plan on putting to many "limits" on what Smoosh and I will try in the "Nasty containment vessel"[NCV]
Have some Honey doo things going on till Sunday!
Then I will start !
Chet
Thanks Grandma
niofox
@mscoffman
Huge thanks for the help, I'm still in the process of self-taught electronics and appreciate that you would take the time out for a newbie like me  ;D
So here's what I've done:
a) Check
b) Check
c) Check
d) Check
d) Made the modification as best as I understood this point
e) This requires a bit more time, so I'll tackle this one after work
"Because of the low beta of these transistors, significant signal
drive capability will be required in the Signal Generator. This may be
better handled by one additional buffer transistor feeding the other
three bases."
Would it be better to do this or just find a more suitable transistor spec to replace the MJL21194?
Thanks again!
Edit:
Forgot to change the solenoid values, but just pretend they are different values each
