My Theory: The Nature of True Balance & Perpetual Motion
Started by Alexioco, August 01, 2010, 08:07:05 PM
AB Hammer
Alex
  I just spent 12 hours armoring and 5 hours of it polishing stainless steel to a mirror finish in 104 temperature. 7 Days left of armor hell then a long nights sleep and maybe my brain will work for deciphering again.  :-\  LOL
Alan
Alan
The Eskimo Quinn
yes it is quite amaiing that both gravity and an anti gravity effect are both cuased by spinning objects,  science shops have the small spinning wheel that balances on a pin, velocity causes the effect but without weight there would be no effect, so the weight must transfer. I see the goal of your question. how can you use the effect to alter the weight displacement of an object to gain or lose weight in a device to create an imbalance or shift. I will have to think about this for you
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
The Eskimo Quinn
yes i have thought about this for 10 mins or so and believe i have the design concept for your machine.
Now to first prove the theory is correct before spending any large sum of money, go to a national geographic shop or similar science shop and buy two of those string spun metal tops that balance on a point when spun, get a digital scale a weigh it, now spin the top and place it on the digital scale, by my logic it should now read lighter, if this is the case which it should be, then you can build a machine.
Now take a wheel with 3 full or 6 radial arms, at the end of each arm would be a motorised top with a heavy flywheel sitting horizontal, as each arm passed the 6 o'clock point it would receive a charge to keep it spinning, the newly charged tops will always be on the left and travelling faster than those slowing on the right after 12 o'clock thus should always be lighter, the energy from the main wheel can be used to power the small top engines, naturally all engines would need to be running for some time to get a flywheel effect happening to then rely on the tapping effect of the charge. We shall call it The "Triple AAA flyer" :) (ALEX,ARCHER,ABHAMMER) hope this helps with the use of this physics effect have fun with it.
NB: you should not that the tops may only be able to sit supported in a cage not be fixed to the arm, this design of the top is somewhat complicated but certainly well withing normal mechanics, the charge can be simple brushes like an AFX car or carbon brushes on springs like a drill. the ultimate would be to have a huge magnetic array on the central tower and coils on the arms proving the power from induction for the tapping effect.
PS: Sorry forgot to tell you why to buy 2 tops, so you can go home get a small pipe bracket/u bracket for walls get a sligthly smaller piece of pipe for you axle and place a ruler on top for your see saw, now simply put small divots in each end and tape one on, now make sure the other is balanced when in the divot or for best effect lower than balance, give it a spin and place it on at level or lower, and it should rise up past level, a working machine to prove your theory to everyone who ever questions that you are a clever guy, whether you ever build a full machine or not, you can prove your theory works in the real world
The Eskimo Quinn
I was thinking about how in glass and chrome how really awesome this machine would look, a giant rotating wheel with these multiple arms, with discus shape glass flywheels spinning in the end of each arm, surrounded by chrome cages that are held suspended radially from 45 degrees above the keep the disk level, the motor is fixed to the cage to remove alternate rotation, with the spike protruding from the base of the top sitting in a divot on a plate, a plate which  like a ferris wheel car sits on its own axle that remains level no matter the position of the arm, without the sliding and clunking of moving weights would be almost silent running but for the hum of the small motors. naturally a retail version would have the plate as the power source connection just like the new power mats for phones,  I guess that means we can expect it to look nothing like that at all by the time mechanical practicalities set in  ;D
Alexioco
Your idea seems good, but I was thinking more of using a wheel with weights inside as one giant Tippe Top, so that as the wheel and weights within rotate, the weights are caused to flip upwards and keep themselves upwards and balanced just as the Tippe Top flips the heavy side up and balances. So long as the Tippe Top is spinning, it keeps up and balanced, so must the wheel and weights, so long as the weights spin around, the now balanced weights at 6 and 12 flip up which in turn keeps the wheel spinning. The spinning top directs its force of movement in an outward, horizontal direction, and its imbalance is an sideways/outward vertical direction therefore it cannot fall. Same goes for a rolling wheel which stays up until it stops rolling. So the weights inside the wheel must want to stay upwards and balanced so long as the wheel is turning which of course, the weights keeps it turning. I'm still trying to realize all of this within a wheel and weights. I have already made one build to test. For the when the wheel is spinning, i have attached two opposing weights hinged to lean up and down at a right angle to the wheels rotation so that hopefully the weight at the bottom and top flip up due to the angular velocity, but the weight are caused so fly outward at the bottom and outward at the top.
its good that they fly out at the top, but they need to flip in at the bottom and stay up and in just like the rolling hoop refuses to tilt or topple over due to its direction of force. any suggestion? Ill send pics of what my build is like once i get a cam. I have done quite a lot of building lately...
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
