Hasn't Anybody Done the Aspden Experiment Yet?
Started by Eighthman, August 11, 2010, 05:47:50 PM
sigma16
Quote from: Eighthman on August 11, 2010, 05:47:50 PM
I have searched this and other sites to find out if anyone on this planet has ever done Aspden's capacitor experiment.  I am unable to find anyone who ever has.
His description MUST include concentric capacitors and MUST be powered by a high voltage, not regular caps and not usual voltages.
He seemed to find it incredible that he could find no record of such a test of his capacitor/aether idea. It would be even more incredible to think that No One has ever tried to test his idea CORRECTLY in the years since he suggested it !!!
Eighthman
If anyone has tried Aspden's idea, they are not sharing the results.  I had a pulser that used a coax delay line for the pulse width and it would put out about twice the voltage that it should have measured with a resistive divider, based on the calculated voltage that it should have provided to the load.  I never explored it further as at the time I thought it was just an error.
Worth exploring.
poynt99
One chap tried something here:
http://www.zpenergy.com/modules.php?name=News&file=article&sid=273
Some other references:
http://www.ttbrown.com/forum/viewtopic.php?f=5&t=466&start=210#p16947
QuoteIn another paper/lecture/tutorials of Aspden's he makes reference to a rather interesting capacitor design. An air gap, with concentric cylinders within each other (smaller diameter inside the larger, and hence asymmetrical. But, what about the dielectric differences? If the dielectric constants are also asymmetrical, what would that produce? Aspden used a theoretic voltage of 25kV at a pulse/frequency of about 150kHz. I am thinking twice the voltage and 300gHz pulse/frequency. What do you think?
Aspden's lecture on the subject (mention of Daniel McFarland Cook's coil, heavily discussed elsewhere in this forum):
http://www.aspden.org/le/Le27/Berlin.htm
Mention of the CC in Aspden's article "TESLA VERSUS EINSTEIN":
http://www.aspden.org/arp/2005arp5.pdf
Harold's notes on the Berlin Lecture:
http://www.wmsn.net/Aetherproof.htm
Aspden's Patent application on the device:
http://www.scribd.com/doc/25323773/Harold-Aspen-GB2390941A
And Patrick Kelly's mention of Aspden's work (some Tesla stuff and nice version of Aspden's patent app near top):
http://www.free-energy-info.co.uk/Chapter11.pdf
.99
CompuTutor
Quote from: amigo on August 15, 2010, 05:09:07 PM
I wanted to try it, but after seeing the cost of copper sheet metal that's needed to make a test rig I quickly backed away from the idea. :)
May I suggest inexpensive copper flashing
as is used for the roofing trade ?
It could be attached to a solid material disc
with adhesive (Contact cement) if needed.
Or dual-clad (Double-sided...) PC boards
cut with a hole saw to size needed,
with a lead through a hole in it
soldered on both sides to make it one ?
e2matrix
Nothing made of copper is going to be cheap.  Copper roof flashing is sold by the roll and even just a 12" wide roll (usually 50' long) is going to run $200 or more.
Sears 14" x 10' = $108.  Some smaller sizes might be had for around $60.  It's a raw commodity and so prices for anything copper is ridiculous now.  About 2 years ago copper took a short dip in price for a while.  But it's back up their now and almost everyone is recycling it so makes getting scrap copper even difficult.  Not trying to discourage anyone here and if you just need a couple square feet you might find a custom home builder that would sell you a small amount or a high end roofer.  But I don't think you'll like the price of roof flashing a Home Depot.
Judges
How many square feet do you need I have (guessing)5-6 sq. ft.
Where is the circuit?
Joe in Texas
