a new kind of visible radiant energy?
Started by david lambright, August 17, 2010, 04:01:43 AM
do you like this topic?
yes, i will tell others about it
 no, it is BS
Rosemary Ainslie
JET - HI AND WELCOME.  I cannot tell you how I missed your input.  I've also been struggling to get my pictures up on this forum.  But Jesus has helped me before and HOPEFULLY he or someone - maybe Wilby - could help us all out here.  It would be excellent to show them without disappearing into a link.  Guys - anyone?  Please rally if you can.
Kindest regards,
Rosemary
Rosemary Ainslie
GUYS LOL - these are ENTIRELY the wrong pictures.  Abject apologies.  And I can't delete them.  Hopefully Harti can do this when he gets back.  Really sorry.  I'll try this again in another post.
Hi again,
Just more images of different configurations that we're also going to try.  On the 'staggered series' you must imagine two layers  or one cup on top of another to create a 'near sphere'.
Kindest again.
Rosemary
nievesoliveras
sparks
  @Cleutshowell
     You are working on this probelm from a mathmatical perspective.  Some are working on it from a physical perspective and some are working on this problem from a experimental perspective.  We all need each other and are listening.
  @Smokey
     I had a similar effect  manifest but did not have infrared sight.  I used the only thermal sensor on hand which was my hand at the time and stuck my hand inbetween an iron coil being pulsed at 30kv over ground and ground.   The iron coil was mounted on a 1" thick piece of uhmw plastic.  The ends of the coil extended through the plastic and when energized two plasma jets were emitted from the ends of the iron coil.  This was not the usual spark we see in spark gaps or wires shorting out.  It closely resembled the light emitted from a plasma cutter/  This was not an arc induced plasma carried to the work piece by the ionized compressed air it appeared to be going into the coil and not radiating out of the coil.  The steel coil ends where the light turned to white showed absolutely no signs of heating when examined but there was the light and the sound with no current between anything.  The coil was being pulsed positive,  Anyway I stuck my hand about 12 inches from the jets and to my surprise a cool breeze was flowing.  Not only could I cup the ion wind and feel it slip around my palm my nerve endings picked up a weird sensation I had never felt.  It was like I was radiating cold.  There was a counterflow of energy in that area around the light emitted from the ends of the coil.   The events following this experiment were a huge concern to me.  They could have just been conincidental and not linked at all but enough for me never to repeat the experiment at least not at 30kvpp.  There was no way no how possible for the current draw needed to pulse the open circuit with low frequency that could have effected this much cooling of the medium.  It was like opening a freezer door and the cold dense air inside the freezer heading for the ceiling instead of heading for the floor in a continual stream.  A one ton refridgeration unit could not efffect this much thermal exchange never mind an open circuit.  I believe the ion wind was a loss of density of the air molecules surrounding the pulsed coil.  Unlike a jacobs ladder where the ions float up the ladder creating the plasma conductor needed to complete a circuit these ions were floating up because they were being generated far from the coil at ground level and floating up and out of the ground electrode at a distance not allowing for any discharge current to form because of the insulating properties of the intervening unionized air molecules and the pulse frequency.  I believe that if I had infrared glasses on I would have seen a black zone emanating from the ends of the iron wire coil out into space and then ending where things started to be warm enough again to emit thermal photons not being absorbed by the radiant matter.  This would involve not seeing something that you should see with thermal imagery that the matter is not allowing through.  This is not reflection or refraction but absorption of the photons by the matter where they remain in the matter increasing its mass.  According to the famous equation of Einsteins Mass equals e divided by c2.  Not alot of energy is needed to alter the mass of something.  Alot of energy released when going the other way.  What gives where is the energy coming from.  Again when we convert energy into mass we need very little.  Yet when we convert mass into energy we get alot of energy.  Do you see where I'm coming from.  There is a huge trade deficet.  What gives where is all the extra energy coming from?  Einstein figured it was inherent in the spacetime continoum itself.  When mass warped the spacetime continoum it increased the density of the energy in the field of the mass.  This energy density then is relative to all the rest of the disposition of energy throughout the Universe.  This deep understanding of the nature of things flew in the face of thermal dynamic theorists that could only perceive mass in motion as being of energy.  The timing of the events could not have been any better.  The established physicists at the time were busy going about the tasks of the warmongers and didnt have time to bury Einstein in an avalanche of bullshit supporting their conservative positions.  It is almost like an angel slipped in and let Einstein out of the cage we find steadily being reinforced by the mindcontrollers.  So guys like Bearden are correct we live in a sea of energy.  This sea at various states of density depending on the mass to spacetime ratio.  The ability of man to create mass and then destroy mass is a huge technological breakthrough.
  Will our civilization survive the understanding of nature of a poor patent clerk traveling on a train or will it fall into dark ages where this knowlege will again be lost but to a few "wizards" enslaved by the adorers of darkness?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Rosemary Ainslie
Quote from: nievesoliveras on August 28, 2010, 03:47:12 PM
@rosemary
Here is the first schematic you did of your three cones device.
http://i758.photobucket.com/albums/xx223/aetherevarising/DSC00173.jpg
Jesus
Hi Jesus - thanks very much but I think you've misunderstood me.  I'm really anxious that someone get JETS pictures posted on this thread.  It's REALLY difficult to get these pictures up.  Can you help us out here?  They're brilliant illustrations and Jet's work is ACE.  Would be SO nice to give it due reference.
By the way,  You'll see I've been going through a learning curve here.  Felt smug with my first picture but then messed up badly.  And I can't delete it so will need to ask Stefan to do the necessary when he gets back.  I can't even modify it to take it out.  LOL.  Abject apologies to all.
Kindest regards Jesus,
Rosie
