Can some explain how to tune oscilation from tesla 369 earthquake 2 power
Started by cletushowell, August 17, 2010, 11:55:20 AM
cletushowell
You drop the ohms of a speaker in parallel
moray had 50 bulbs
if they were parallel they must have droped the ohm
to equal zero point the amount the antenna can not
pump energy at that point there has to be some energy
offset so if
you have a known led and known resistance
how do you calculate the amount paralled
back to zero using ohms law the lower the ohm the more power
I need to understand led better and the
resistance to calculate 0 from parallel them
infact you probly dont need led just parrale the
resistors to zero take the led and gas tubes out the equation
did moray or tesla have resistors or just bulbs
cletushowell
I dont know how to build it but I know the answer
counter-wound (parallel) bifilar
thats the answer anyone know how to do that?
cletushowell
Some bifilars have adjacent coils in which the convolutions are arranged so that the potential difference is magnified (i.e., the current flows in same parallel direction). Others are wound so that the current flows in opposite directions. The magnetic field created by one winding is therefore equal and opposite to that created by the other, resulting in a net magnetic field of zero (i.e., neutralizing any negative effects in the coil). In electrical terms, this means that the self-inductance of the coil is zero.
The bifilar coil (more often called the bifilar winding) is used in modern electrical engineering as a means of constructing wire-wound resistors with negligible parasitic self-inductance.
This may help
cletushowell
Found a link
tesla and moray b king
I'm looking for books with information about bifilar-wound coils.  Could you please give me some names?
I have two books which refer to bifilar-wound coils.  The first is Dr. Nikola Tesla Complete Patents which contains the U.S. Patent No. 512,340, COIL FOR ELECTRO-MAGNETS, described in the following claims:
1. A coil for electric apparatus the adjacent convolutions of which form parts of the circuit between which there exists a potential difference sufficient to secure in the coil a capacity capable of neutralizing its self-induction.
2. A coil composed of contiguous or adjacent insulated conductors electrically connected in series and having a potential difference of such value as to give the coil as a whole, a capacity sufficient to neutralize its self-induction as set forth.
The second book is Proceedings of the 1990 International Tesla Symposium which contains a paper by Moray B. King, "Tapping the Zero-Point Energy and Scalar Current."  The paper refers to four types of bifilar-wound coil, parallel-wound, series connected (as described above), parallel-wound, parallel connected, and the counter-wound caduceus coil, both series and parallel connected.  Also, King's paper "Demonstrating a Zero-Point Coherence" in the Proceedings of the 1988 International Tesla Symposium proposes an experiment involving the pulsed excitation of a caduceus coil surrounding a plasma tube in ion-acoustic resonance.
cletushowell
Well I think we now have the answer
the joe cell from what I gathered the joe cell
is a stainless tubes like the lead cell battery so between the tube is 30%
vinegar that makes the acid the antenna
then would pull through the cell to the positive terminal on the car
the energy is removed with tremendous force
when the points open energy out the antenna
this draws the lead acid backwards instid of purrifying the lead its
by pushing the power thru the positive terminal
its pulling the power out the positive terminal
so the purification in the lead would be reverse it would make the
dc battery more pure not rust so I need some stainless
and Im broke did see the attorney today about my earth battery arrest
mabey it will get dropped the cop wrote a shit load of lies including
trespasing me attempting to hit him all kinds bs
for his harrasment and pepper spray I was on my fucking property
well anyways court in two days will probly be drawn out
the joe cell is then changing the ph electronicaly
something a meter or ph scale will probly not show
electrolosis desolves aluminum by essentialy making the power
the acid this is why my earth battery had so much power
acid salt there oposites so the stainless
can take the uv rays from the sun thru the antenna aparently
without making rust I knoticed they polorised the stainless both ways
and dont let it get hot im thinkinh the tubes should actualy
be close as possible so the energy thru the antenna transfer is good but you know theres so much power when you disconet the grount going out the antenna it must be directed to the piston by turning the
timing maybey the antenna goes in the
intake that makes a lot of sense
to me the radiation bounces from the steel thru the aluminum
tube is aluminum a barrier for uv rays
or stainless i know lead is thats why the lead ruines
so fast well good luck to any joe cell builders
i heard it lifted a truck 2 inches of the ground and bill said it
spun the tires like a indy car I think because it was lighter
under the most power draw the more the points are open the more goes out the battery to antenna oh so what its doing is making
the ph - so the hydrogen is removed from air
not from water its working reverse so the energy
from the water is removed this would make
water and the ion flow thru the negative battery post to the antenna
interesting so the collapse of the coil
throws the pulse back to the water it finds the best release the antenna
the points close it flows thru the car coil again
ya this should work I dont see no flaws but tunning it
