Crystal Power CeLL by John Hutchison
Started by dani, April 26, 2006, 04:11:36 PM
PaulLowrance
It might be difficult to place a weight evenly over the piezo. Perhaps a better idea is to place the piezo at the bottom of a vial of oil. Not sure how much pressure that would be if the piezo is say 1 foot under oil.
jadaro2600
According to the DIY, it seems a relatively large crystal with uneven features still prevails ( so much for the di-lithium di-lemma ).. :)
Anyhow, I've mentioned the plaster of paris here.  Why not set the crystal in that placing a thin electrode to contour the outer surface and then filling in the incongruities with plaster ( which can take some pressure btw ).
This could easily be formed in such a way that you have an uneven crystal and an even contact, and well as a even mount.
I suppose the best thing to do would have two separate sides so that the plaster doesn't join and prevent flexing of the crystal, pour them independently; make sure that the electrodes contact the surface properly, and their leads are appropriate.
One could also use the compression of two magnets to apply pressure.
Pirate88179
Jadaro:
I like the 2 magnets idea...good thinking.  This would allow any orientation as opposed to using gravity.
Excellent idea to try.
nitinnun
the copper works,
because it is diamagnetic.
bismuth produces more voltage,
AND more amperage,
than copper.
because bismuth is the most dia-magnetic,
of ALL stable elements.
steel is also more negative than aluminum.
steel produced more voltage,
and amperage,
than aluminum did.
you all depress me.
with your fixating on exotic chemical combinations,
instead of focusing on WHY it works.
if only you focused less on materialism,
and more on the philosophy of why it functions.
then we would be far further along by now.
ian middleton
G'day all,
@nitinnum, ok mate, you lead the way.
