Thanks to ALL for your help!!
Rodin/Starship Coil and Earth Rotation
Started by Atlastired, September 28, 2010, 10:58:44 AM
Atlastired
Quote from: Qwert on September 30, 2010, 03:01:53 PM
This could be true IF all particles have exactly the same speed. Since they don't, those slower collide with faster all over and their path from the beginning is, well, just more or less CHAOTIC. In addition, when they reach a planet's (Venus in this case) atmosphere or surface, some of them also reflect and collide with those later coming. In effect, the space behind Venus is full of particles which more or less chaotically go to the Earth.
The particularity of Venus is that she dsnt have a Rodin/Starship Coil around her and do not rotate (1 rotation +-243days) she is not creating a vortex around her and NASA probe discovered no activity behind Venus.
The Solar wind Crash upon Venus and form a comet like tail on her sides, that is observe in every Venus Transit by the "Ink Drop"
So by implying that the direct radiation that is going to Earth is not itself deviated by other particules at the same ratio making it a nul effect. Earth is a target millions of KMs away Smaller thab what Venus look like in her transit. So good luck to the particules if they are not direct they are more than lucky.
Direct Radiation Is what Venus is gonna Block, if you believe thats will have no effect on our Balanced System, you are blind to all the changes that occured since the last 2004 transit.
BTW the Arctic melted back in 1882 after the Venus transit, and the little green aliens were not invented yet.
It is all about the right angle, and Venus is coming back a few degrees lower each time. Blocking partially the full Solar Wind until the right angle where she is blocking the full monty.
Then...Read the Bible, it is described what will happen.
Chaos has a little bit more order than you think
Qwert
Quote from: Atlastired on October 01, 2010, 04:37:55 AM
The Bible says that the Sun revolves around the Earth. Should I believe that?
Qwert
To be exact, the Bible says the sun is rising in the east, traveling across the sky and setting in the west. And the Catholic Church believed that word for word.
Qwert
Then, what is your advice anyway? I smell a big cataclysm here... Should we pray, or kill ourselves?
Atlastired
Beside trolling what are you doing for a living?
