Electricity Amplification Device - It's so simple !!! (Hatem Magnetic Cogging)
Started by bimbothova, October 13, 2010, 11:40:13 PM
hoptoad
Quote from: exnihiloest on October 22, 2010, 06:36:16 AM
Beautiful, like most of the products of delusion.
Thanks for the great belly laugh. Delightfully succinct !  ;D
Cheers
hoptoad
Quote from: Low-Q on October 21, 2010, 03:59:11 PM
Many hobbyists out there often have lack of knowledge, and do many times believe they add 2 x 2 and gets a product greater than 4. Yes, it is possible to make readings of voltage and ampéres which in the first plase looks like it makes more energy out than in. But in such cases there is a given phase shift which is resulting that voltage and ampéres are not syncronized in time.
An example:
A person makes this device, and measures 10V and 10A input. Then he loads the output and read 20V and 20A. Any person with a common sense "understands" there is 400W out - or are they wrong? What they overlook is the phase. Say the real input are both volt and ampére in phase; 10 x 10 = 100W. The real output are in best case (20V x Cos65) x (20A x Sin35) = 97W - take this as an example. Now you can try to loop the device and try to feed 97 Watts into an input which require 100 Watts to run. This is the very reason this particular device cannot bee looped, and ran by itself. The explanation are all there. There are no energy from space which is harnessed by a magnetic coupling. It is all about the relationship between the VA-readings and its phase.
Vidar
Well explained Vidar. Unfortunately, the mistake of omitting the phase relationship between current and voltage from the power calculation is one that seems to be 'perpetually' repeated on this site and other forums. What a pity we can't extract free energy from perpetual misunderstanding.
Cheers
It's too bad that everybody thinks they can't afford an oscilloscope since good digital ones are so expensive.
While there are perfectly fine and usable analog scopes on the used market in the 100 dollar price range.
A voltage trace and a current trace (voltage across a known small resistance in series with the circuit under test) can be displayed simultaneously on even the most basic two-channel oscilloscope. The instantaneous multiplication, point-by-point, of these two trace values will give an instantaneous power curve, and the average value of this latter curve can be found easily. And this process completely and automatically accounts for any and all phase shifts between the two signals and yields an accurate result.
The only advantage of a DSO over an analog one is that the DSO is a lot more convenient and easy to use. You can spend 10 thousand dollars on a DSO to make this measurement, to four or five digits of precision, and have your answer in moments. You can spend 100 dollars, take a photo of the screen with your cellphone and spend some time analyzing and multiplying by hand to make this measurement, to three digits of precision in a couple of hours.
We are not talking high bandwidth or complex signals here, just power measurements in a phase-shifted situation.
The oscilloscope is the king of test equipment and, along with a basic signal generator, is at the heart of any home electronics setup. Spend a hundred or two on a 20 MHz scope, learn to use it properly..... and you will never regret it.
bobby_tc6
All information that I have about Hatem's Magnetic Cogging Generator ...
https://www.dropbox.com/sh/69km97qu5jdr6u1/JrDstQcQOk
@Tagor .. I am not Mindfreer ... I wish he could join this forum and provide us more information on this generator design.
Two of the videos uploaded by me were created by Mindfreer which were available on youtube until few months back they were removed by google siting copyright issues ... I failed to download Mindfreer's later uploads which had more information on the Hatem design ... the videos were deleted by google within a week's time of uploading .. strange .. looks like Mindfreer was on to something and there was someone who didn't like him discussing it so openly.
George Mitchell is the only other person (one of the videos uploaded by me wherein there are three rotors) who has succeeded in replicating this design but he would not divulge the specs of his setup.
tagor
Quote from: bobby_tc6 on August 05, 2012, 04:34:54 PM
I think that Mindfreer is a con man
I know Hatem there is nothing working in his house , I spoke a lot on this in this forum
but nothing working ...
