Electricity Amplification Device - It's so simple !!! (Hatem Magnetic Cogging)
Started by bimbothova, October 13, 2010, 11:40:13 PM
bobby_tc6
There is lot of very useful information given in the PDF file that I have uploaded which I guess is put together by Yannick V. D.
And IMHO stamping a design as non-working or SCAM or FRAUD without ever testing it, is not right.
tagor
Quote from: bobby_tc6 on August 06, 2012, 02:41:20 AM
yannick another con man , he stops selling plan when I spoke of this on a lot of forum
Hatem is fool but he is not selling his craps
EDIT :
there is a lot of testing of the hatem device on french forum !!!
look what I posted on this !!! it is not new !!! 2 or 3 years ago ...
avalon
Quote from: Low-Q on October 21, 2010, 03:59:11 PM
This is the very reason this particular device cannot bee looped, and ran by itself. The explanation are all there. There are no energy from space which is harnessed by a magnetic coupling. It is all about the relationship between the VA-readings and its phase.
Vidar
I agree in principle though I cannot be categorical that there is no excess energy in magnetic coupling. I simply don't have enough information to say one way or the other. But I totally agree on the misreading of the output - a common mistake.
Gwandau
In the midst of ideas setting off the scam alert warning, we may miss the real ones.
Magnetic coupling employed in a far more sophisticated way by these guys:
http://pesn.com/2010/07/14/9501672_Terawatt_Research_LLC_defies_free_energy_stereotypes/
What's your opinion?
Gwandau
Gwandau:
From their web site:
The Test Set-up: Interactive Magnetic Oscillations The current design of the set-up is based on a magnetic interaction where one body interacts with a second and third body.
  • The first body (4) on shaft 1 is a magnetic drive driven by motor (3).
  • The second body (5) on shaft 2 is a Magnetic Torque and Speed Enhancement Device.
  • The third body (6) is a Magnetic Oscillation Device that amplifies the interaction between the first body (4) and second body (5).
  • There are two rotational torque sensors on two shafts (Futek Advanced Sensor Technology Inc.).
  • Each sensor (1) (2) is mated to an evaluation instrument (Kistler Como Torque 4700).
  • Each instrument is connected with RS 232 to an individual Computer.
  • The Data Acquisition System and software to analyze and record the Sensors is provided by DATAQ Instruments, Inc.
I believe that many of these companies just exist to be "in development" for years and years - and that is their business.  That is their "product."
Do you follow me?  They are in the business of the business of tapping into the vast pool of venture capital investment money out there.
These two lines:
Now, you can take a strain gauge and rotate two magnetized disks that are set up to interact and measure the torque for every single degree of rotation.  You will end up with net zero energy after you rotate 360 degrees.  (Approximately zero because of the imperfect granularity in your measurements.) This comes from James Faraday and James Maxwell all the way on down.  You analyze the setup with calculus.  Instead of making a measurement for each degree, you use calculus to reduce the step size to the limit towards zero degrees and compute the line integral that an imaginary point follows as it rotates through the 360 degree circle.  The resultant of the line integral is zero and the calculus is perfectly modelling the physical system.
If you accept what I state to be true and verifiable on the bench and verifiable with calculus, then you will conclude that the two statements above are lies.  Twice they say that there are two mechanical amplifiers that put energy into the system from nothingness.
So in my opinion, Terrawatt is just a poor man's version of Steorn.  Look at the example of Jame Kwok and his "Hidro energy towers."  Someone once posted that they contacted James Kwok about financing a real installation and James refused with the poor excuse that he was not set up to do business in the customer's part of the world.  I think it was in the NW United States.  So James Kwock is also in the business of the business of tapping into the vast pool of venture capital available in the world.
Sterling's article was from 2010, it's now 2012.  I can't explain why when you look at the "About Us" page you see pictures and mini bios of about a dozen of what appear to be perfectly respectable people.  None the less, this appears to be a junk company making the dead-beaten-horse claim about "energy from magnets."
These things can be very offensive if you forget about the lure of over unity and just look at this at face value.  There are people who work in professions related to what this company does and they are flabbergasted to see other people apparently masquerading around and making a mockery of science all for the almighty dollar.
Now that was a good rant!
