Relative Permittivity of Water
Started by Torana, October 14, 2010, 04:35:01 AM
wfchobby
thankyou.
a link to the Sandia article from google is:
www.sandia.gov/pulsedpower/prog_cap/pub_papers/022611c.pdf
Torana
This was sent to me .Thnx.   (O.U.R)    (....R?)
http://www.overunityresearch.com/index.php?topic=125.0
1; it takes brute force from a prime mover to turn an Alternator , Generator or Faraday gen.
2;Ingress protection rating applies to water around electrical equiptment because water and AC do not go well .  High polarizability.
http://en.wikipedia.org/wiki/Ingress_Protection
3;If a stator coil (3) is brought to a closed conducting path, one of its effects is to behave as a shade ring , effecting the core.   If its a dead short in normal running ,its a melt down.
http://en.wikipedia.org/wiki/Shaded-pole_motor
4;Water caps do not generate hydrogen gas, its not a function. Thats a function of a cell.
5;Faraday gen = DC , the brute force electrolysis stuff.
Stan meyers captured peoples imagination.
Capture; to take by force ,surprise or skill**
Torana
No!  i have never built an 8XA and never will.
learn electronics/electrical theory and then youll be able to trace a circuit to see if
its a red herring.
DREAMING = gate f higher than anode f , variac.
Just for laughs wouldnt it be easier to use a store bought 3 ph switchmode pwm chip???
eg; UC3620, UC3622,...
but only if you beleive thats the key
water is a non linear R = NON OHMIC
non linear components eg; transistor, diode , valve etc
electrochemical = NON OHMIC , no current flow until the redox potential is reached.
If anyone changes any part of the 8XA , logically that should indicate 8XA is BOGUS , eg;
"modified" "updated"  "new improved" "revised" ...
people with electronics exp **should** know better , the main f is from variac , itll
produce set amount of gas anyway .
H2 sites never show circuit component spec explainations of Horvath,Puharich or Meyers
,it would fall over straight away.
Stan Meyer and puharich did a lot of damage to stifle "replicators" ,its worked every year for 31 yrs!!
Question; How did Stan protect himself from YOU ???  OR..
How would YOU stop people from copying YOU???
**give yourself an Honest answer.
Your the consumer , thats the natural order.
Torana
J
1.that things a door stop!  that admission wont come any time soon
2.I wont follow those links , Im just not interested in what those guys are doing
3.The formula youve got is for a closed circuit = finito (Finite)   radio, TV etc the environment is part of the circuit = open
4.Look at 12 v batt , all components including the casing originate from the ground.  earth is sink or source.   look at ground to air lightning or volcanic eruptions.
Hydro dam = mass of electron and proton in form of H2O are used to force a turbine under gravity to move electron in Cu.
again all components of the dam and grid are from the ground  .  solar panels,coal,oil ,uranium , all from the same place.
on the fundamental level...we have nothing , we have to manipulate the environment to get energy.
5.  =NO!
6. = DONT KNOW  = go ask    (not MYN)
Torana
youll find him here .....I shouldnt have to say it but.....*something* tells me I DO....
**HE WONT ANSWER YOUR QUESTIONS** .
no one associated with meyers is going to say anything ,it takes time for people to wake up (hind sight)and no one of any standing can support the literature , its laughable and full of solid crap.
**try and find an electrician ,electronics tech or uni student to back up any of it.
ANY OF IT!!
http://www.boltontrust.com/about-the-bolton-trust
