Does the Earth Have a Net Electric Charge, and Can That Be Tapped?
Started by ResinRat2, February 02, 2011, 05:27:04 PM
ResinRat2
Possible solution:
http://www.motherearthnews.com/Do-It-Yourself/1970-07-01/How-To-Drive-A-Well.aspx
I need to check local laws, obtain necessary permits, equipment, etc., etc.
All to drill a hole in the ground.   :P
Here is another way: http://www.howtodrillawell.com/
Dave (RR2)
IotaYodi
QuoteAll to drill a hole in the ground.
If its just a pipe in the ground without a well head you may not need a permit. The reason for permits is water management needs to know whos tapped into the aquifer. If your not putting a pump on it I would just do it. Dont know of any code or law that prohibits you from driving a pipe into the ground.
I have about a 140 foot in ground pump. Its 1 inch galvanized. From a short 6 inch copper pipe to the galvanized pipe I get .39 volts with my good meter.
What I know I know!
Its what I don't know that's a problem!
ResinRat2
Hello IotaYodi,
     Your deep pipe would need to be insulated from the ground surface all the way to near the bottom of the
pipe. That way there would be no electrical connection to the ground and the surface except at the very
bottom area of your pipe. That would mean both inside and outside the pipe is insulated. Also, both pipes
would need to be the same metal so no galvanic reaction is taking place. Between the copper and the gal-
vanized pipe you will get a galvanic reaction. I believe that is what you are seeing for voltage.
     Thanks for trying though. This project is not as simple as I thought it would be. I appreciate your input.
Dave (RR2)
IotaYodi
QuoteAlso, both pipes
would need to be the same metal so no galvanic reaction is taking place. Between the copper and the galvanized pipe you will get a galvanic reaction. I believe that is what you are seeing for voltage.
That is correct. My galvanized weather mast has very low readings also. Never got a lot of voltage from galvanized pipe.
Bill brought up something in this thread about the reverse polarity with the trees. This might be relevant when wiring up an Ns coil or earth batteries. I would think someone knows the reason for the polarity reversal. If not we need to find out why.
What I know I know!
Pirate88179
Quote from: IotaYodi on February 05, 2011, 06:44:10 PM
Yes, exactly.  I know it really may not have anything to do with what RR is suggesting here but, everyone should try the experiment I suggested.  It only takes a few minutes and it goes against everything I was taught about "ground" being minus.  I should make a quick video of this to find out what others think this is telling us.
