Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
Slovenia
Sun Gazing
I've been doing a lot of research on how to activate the human brain since Power To Be got me interested in this area.  I discovered there are many ways to accomplish this.  One of the less complicated and straightforward methods is by Sun Gazing.  It has been practiced by many ancient civilizations for a long time but pretty much kept quiet in recent times.  It enables the brain to be activated to full capacity and also the pineal gland.  It also enables man to go without food for long extended periods of time.  One yogi hasn't eaten since 1995.  Anyway, for your pleasure and our research:
http://www.scribd.com/doc/48567043/Sun-Gazing
Slovenia
I think this is very pertinent to the electric wind or ionic scenario.  Anyway, last night I woke up with this on my mind, so I want to share it in case it will help someone.
A post of Power To Be came to mind last night while I was sleeping.  I will refer you to the post so you can read it for yourself and come to your own conclusion.  Anyway, Power To Be brought up a point in Aaron's thread on Energetic, "Spark Plug 2".  He said that the Luc circuit was adequate to do the job.
Anyway, please refer to that thread in my compilation of Power1 posts.  It is somewhere toward the back of the pdf file.
Share what you believe to be true.
Link to Updated "Compilation of Power1Posts":
http://www.scribd.com/doc/52177573/Compilation-of-Power1-Posts
superman9976
So I have been thinking for the past few days.  I keep thinking the substrate could be steel since zinc naturally adheres to bare steel.  I will try this idea this weekend.  It seems the transducer is where the crystals are adhered right on to the disc.  If I cut a circle from a piece of sheet metal grind off the coating and soak it in heated mason jar with my crystals and allow it to dry will this be a start to a transducer?  I could take silicone and put a few dabs on the disc and this would adhere to some solid material (like little stand offs) but still allow it to oscillate with the pierce crystal oscillator circuit attached to it.  Of course I would have to put the homemade transducer in a container and then attach a balloon to the opening of the container to capture the gas.  The faster the balloon fills the closer I get to the right oscillation. I should build this pierce circuit with adjustable capacitors inducers and resistors like a varible cap varactor diode or a pot.
Am I to figure a fundamental frequency with overtones?  Or does the fundamental frequency just automatically produce overtones?
I will keep thinking about it and looking at my books.  I have a friend I can ask too.  But if you power to be can help in anyway like component selection?  This stuff is a lot to take in for a beginner.  I definitely want to learn about it though.
I think the toroid transformer will be the easiest part but the pierce circuit will require the most work.  The build my own transducer idea is just out there I never considered building my own.  I am wondering where I would place the leads.  Is it a two wire setup or just one to get it to oscillate?
The CDI project is taking a bit longer than I thought but definitely showing signs of progress.  I am coming up with ways for a good heat exchanger for my mag heater project.
Solvenia I got a price on the transducers $11 ea. plus the shipping which is probably $61 like you said but I am holding off until I try to build some things for now.
Chris
Slovenia
Anybody else working on this project?  I know there are two or three of us still kicking.  It would be helpful if we got our heads together and shared a little bit.  I'm really into it but don't have the electrical background, so it's a real slow progress for me.  I would like us to show Power To Be progress really soon of some fashion or other.  I'm used to working as a team on these projects, and I've put a lot of effort into this project to help others and keep it alive.  Of course, in helping others I also helped myself in the understanding aspect too but I was expecting a lot more from the group than I am seeing.  I'm having to find experts outside this forum to help me now and that's making me take a hard look at some things if you get my drift.
eisnad karm
work on what exactly? have a read of the thread..there is no grand design
Mark
