johnny874
   see3d,
he has one, the replicate would also have one.
Of course,  my car has a battery.
Coincidence ?
  Johnny
edit. will someone put that 2 thousand to work please ?
johnny874
KanShi
I've been thinking about how to best demonstrate the relative lift of the ZED and realized, the best would be visual, mathematical and physical comparison with regular lifts:
You can see the visual comparison in the attached image (the pod is of course full of air - it is drawn as full for visibility reasons).
As you are going to see, in all compared devices, the pressure exerted on the pod is the same (those with the pod +h2·ϱ·g) => every device has the same input requirements: fluid at the same pressure. What is also demonstrated is that multiple risers just increase complexity and that just one tall water column is needed to generate the ~same pressure and lift (with the ~same input).
To precharge the devices, we pump-in air at the required pressure and thus displacing water; or, in other words, increasing the potential energy of the device and storing it in the water column(s).
ϱ(water) = 999,7026 kg/m^3 (at 10 °C);
g = 9,80665 m/s^2;
h1 = 2m;
h2 = 1.5m;
A = 1 m^2;
hydrostatic pressure: p = ϱ·g·h = h·9803.73350229;
ZED:
p1 = 2·9803.73350229 = 19607.46700458 Pa (19.61 kPa);
p2 = p1 + 1.5·9803.73350229 = 34313.067258015 Pa (34.31 kPa);
Lift from pressure: Fp = p1·A + p2·0.9·A - p1·0.9·A = p1·0.1·A + p2·0.9·A = 32842.5072326715 N (32.84 kN);
Lift from pod: Fb = ϱ·g·V = 9803,73350229·0.8·A·h2 = 11764.480202748 N (11.76 kN);
F = 44606,9874354195 N (44.61 kN);
Hydraulic lift / hydro-pneumatic lift:
p = (1.5 + 2)·9803.73350229 = 34313.067258015 Pa (34.31 kPa);
F = p·A = p = 34.31 kN;
Hydro-pneumatic lift with a pod:
p = 34.31 kPa;
Fp = 34.31 kN;
Fb = ϱ·g·V = 9803.73350229·0.9·A·h2 = 13235.0402280915 N (13.24 kN);
F = 46077.547460763 N (46.08 kN);
The weight of air is ignored - as it is also ignored with ZED. It is only approx. 8.28N anyway.
johnny874
  If you guxs want to do a simpldd test, get a garden hose. All yott need to do is adjust the nozzle. The pressure in the hose does not change, how dver it,s flow rate does whem
you adjust the nozzle.
@micro, it,s old wayne and friends saying it,s a working over unty device.
such claims put the burden  of proof on those saying they have done it.
neptune
Quote from: johnny874 on June 20, 2012, 11:22:17 PM
   see3d,
Coincidence ?
  Johnny
As has been stated, a simple model to demonstrate OU [not a self runner] would not need a battery .
                                              CHECK LIST
        JOHNNY`S CAR                        WAYNE`S  MACHINE
Battery fitted?                                                            Yes                                              Yes
Is battery charged by the machine ?                              Yes                                              Yes
Is the battery the actual main power source?                   No                                               No
If you removed the battery, and made no modifications,
would the machine still function?                                    No                                                 No
What a coincidence, as you said. Give it up, Johnny.
None of us live forever. Concentrate on your Bessler work.
